Most Useful Tools...
42 replies to this topic
#16 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted August 14, 2013 - 04:22 AM
I too use my Leatherman several times everyday. I feel like I am naked if I don't have it with me.
Sidenote....My wife's uncle owned the machine shop that made the hinge pins for the Leatherman.
#17 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted August 14, 2013 - 02:56 PM
Here is one of the handiest tools I've ever owned. It is a tool that I couldn't have done without when building my jeep... among MANY other projects! It is marketed toward work workers and when I bought it I was doing a lot of wood working. But it is great for great for any time you want to keep something at a certain angle in relation to another object. It has a magnetic base so you stick it to your referance surface (jeep frame) hit "zero" and then stick it to what you are measuring (pinion angle maybe?). You can also zero it to bubble level for use as a digital angle.
http://www.wixey.com/anglegauge/#wr300
So what is handy in your garage?
I gotta get one of those.
  • twostep said thank you
#18 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted August 16, 2013 - 11:10 PM
Leatherman "Wave", 2 DeWalt cordless drills, deadblow hammer and 2X magnifying glass.... (and for dealing with the results of the first 3, paper towels and duct tape.:D)
#19 jdslednut OFFLINE
jdslednut
  • 679 Thanks
  • 851 posts
Posted August 16, 2013 - 11:14 PM
Love my Gearwrench Quad Box set. I think that's what it's called anyway.
#20 TerryD OFFLINE
TerryD
  • 132 Thanks
  • 254 posts
Posted August 17, 2013 - 12:09 AM
A set of long needle nose, side cutters, nippers ect. The miniature kind. Came from HF. I use them all the time to fish out small parts, cut wires, and so forth. Next in line.....my 3/8" cordless drill.
#21 UncleWillie ONLINE
  • 15,676 Thanks
  • 8,763 posts
Posted August 17, 2013 - 01:02 AM
One of teh handiest things in my shop is a monster pair of hemostats that I found in the road. They are about a foot long and are the absolute best thing on earth for getting that bolt that fell into a black hole or pinching off a fuel line. Then they aren't in use I can clip them to a shirt sleeve to keep them handy. I have many smaller pairs but those big boys are my go to tool.
  • LilysDad said thank you
#22 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,322 Thanks
  • 9,788 posts
Posted August 17, 2013 - 07:19 AM
I'd like to watch a master at work! :D
#23 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,470 Thanks
  • 5,770 posts
Posted August 17, 2013 - 08:07 AM
It's usually the one that isn't in arm's reach when I need it..   :wallbanging:
It totally depends on the job I'm performing @ the time..
Tractor tinkering-  Wrenches & Ratchets
Tractor engine or any engine rebuilding-  Calipers and Mic's & Bore gauges
Electrical-  Multi-meter then my handy 4-in-1 screwdriver then cutter/strippers/crimper tool
Plumbing-  Slip-joint pliers and crescent wrench
Carpentry or any other job listed above-  TAPE MEASURE!!  Seems to be used all the time!!  We have a winner!
#24 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted August 17, 2013 - 08:25 AM
Okay:
I am surprised that no one has said it yet.
So I will.
The handiest tool in my shop is.........................
ME!!!!! :rocker2:  :rocker2:  :rocker2:  :rocker2:  :rocker2:  :rocker2:
Ya I said it.. :D  :D  :D
  • olcowhand and limebuzz have said thanks
#25 HDWildBill OFFLINE
  • 8,975 Thanks
Posted August 17, 2013 - 09:53 AM
Another tool I use a lot is the telescoping magnet.  Not only is it good for retrieving bolt's and nut's that I have dropped down in a hole but also when I drop my wrench on the floor or under the work bench.  A lot easier to extend that magnet out and pick it up then bending over or getting down on the floor to get it.  It's hard getting old. :(
Willie you are right, I have a pair of hemostats and they are very useful.  They are also useful to hold two wires together as you solder them together.
#26 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,322 Thanks
  • 9,788 posts
Posted August 17, 2013 - 01:15 PM
I changed my mind. My most useful tool is the service manual!
#27 CRFarnsworth ONLINE
CRFarnsworth
  • 4,678 Thanks
  • 2,149 posts
Posted August 17, 2013 - 03:41 PM
Three of my favorite tools and my backup tool.  If you can't fix it with a hammer, you have an electrical problem!!  :D  :D  :D    Rick
  • HydroHarold, LilysDad and BigA have said thanks
#28 BigA OFFLINE
BigA
  • 10 Thanks
  • 21 posts
Posted August 17, 2013 - 04:47 PM
:bigrofl:  :bigrofl:  :bigrofl:  :bigrofl:  :bigrofl:  :bigrofl:  :bigrofl:
#29 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted August 17, 2013 - 05:46 PM
Okay:
So I will.
Where were you today! I could have used some help!
  • BigA said thank you
#30 Canawler ONLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted August 17, 2013 - 08:08 PM
Whoa! Be careful throwing around comments like that.
You could loose your Man Card. :poke:
  • LilysDad and BigA have said thanks
