I've About Had It With Engines!
25 replies to this topic
#16 boyscout862 OFFLINE
  • 13,450 Thanks
  • 9,394 posts
Posted August 13, 2013 - 06:57 AM
The weedeater may be that the new filter is defective and or the fuel line is blocked inside. A few weeks ago one of the threads mentioned that a fuel line had constricted and shut off its flow. I'd pull the line and filter and carefully inspect the flow rate using a boat gas can pump to pull a vacuum. Good Luck, Rick
#17 Alc OFFLINE
  • 7,132 Thanks
  • 7,533 posts
Posted August 19, 2013 - 05:41 AM
Just wondering if you found the problem yet ? I'll be looking at my chain saw I think , ran and then wouldn't restart
#18 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted August 19, 2013 - 08:13 AM
Not yet.  I'm taking the weed whacker to a friend of mine who used to work on them for a living.  Taking the kart some place else.  These need to run and I haven't got the time to even look at them right now.  I'm sure it's something very simple but everything takes time.
#19 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted February 20, 2015 - 08:15 PM
I have stopped using Ethanol Gas in anything other than on road vehicles. We have regular no ethanol available close buy and 25 to 50 cent per gallon difference is worth it to me, I was constantly replacing fuel lines on weed eater, hedge trimmer and anything 2 cycle. Plus the blood pressure stayed up more than I needed.
#20 MH81 OFFLINE
Posted February 21, 2015 - 08:15 PM
I'll have to pencil it in for some time in 2015
Did you ever get it penciled in?
  • David Brown said thank you
#21 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted February 21, 2015 - 08:54 PM
Not yet.  I had to go back through the whole thread to even remember what I had to pencil in.  Now that OT will be dying down in the next month, I need to get to some of these projects.  The kart ran good last time it ran (where have we heard that before) and the weed whacker has worked flawlessly all winter:).  We'll see what happens when I actually have to use it.  I really want to come north a little more this summer to some things that group French Creek is doing.  Will that happen?  I'll let you know in the fall.  That's such a nice group and they do some really cool things.
#22 KennyP OFFLINE
  • 40,240 Thanks
  • 46,811 posts
Posted February 22, 2015 - 07:13 AM
One of those 'Ran great when I parked it' things! Good luck!
#23 JBRamsey OFFLINE
JBRamsey
  • 1,548 Thanks
  • 872 posts
Posted February 22, 2015 - 10:08 AM
Check the primer bulb on the weedeater. Make sure it's not cracked and sucking air.
I had a dirt dauber build a nest in a brand new chainsaw muffler a few years back. It idled perfectly and died as soon as I gave it throttle. Almost drove me nuts figuring it out.
I use pure gas and StaBil in everything and try and run everything once a month or so. I let my main mower run until it's dry at the end of the season. So far that's workIng for me.
#24 dodge trucker ONLINE
dodge trucker
  • 2,714 Thanks
  • 3,357 posts
Posted February 25, 2015 - 09:06 PM
I wish we could even get "ethanol free" gas.   Last I knew there were 2 stations in all of Illinois that had it, both over 150 miles south of me (there used to be a website where you could look up those sort of places)
#25 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,279 Thanks
  • 4,513 posts
Posted March 06, 2015 - 11:32 PM
I have to use ethanol gas, but I have been making a mixture for over 5 years now. 5 gallons of gas, one oz of the red Stabil, and one oz of STP gas treatment. I have been using this mixture in all the tractors, and mix in a 1 gallon can with oil for the weed wacker. Not had a starting issue out of any of them, even after sitting dormant for months.
#26 oldedeeres ONLINE
oldedeeres
  • 10,349 Thanks
  • 5,046 posts
Posted March 19, 2015 - 11:08 AM
One of My Olde Deeres pet peeves--- try finding a gallon can up here anymore now that we're all metric! It used to be so easy to make a gas mix for chainsaws etc. Folks go to yard and auction sales and get the older cans , (not plastic) just to have some on hand.
