John Deere Sabre 638 Hydro Gas Leak At Carb
6 replies to this topic
#1 carolspain OFFLINE
carolspain
  • 12 Thanks
  • 14 posts
Posted August 11, 2013 - 06:52 PM
I recently inherited a mid 90's Deer 638 Hydro..
With the Briggs & Stratton Vanguard 16 HP engine.
y problem gas is seeping out of the connection to the dashpot at bottom of carb.
I'm looking for solutions regarding cause and/or fix. Tractor was  in dealer this past spring foe new belts gen tune up, etc.
It's only had aprox 7hrs on it this summer.
Thanks,
Joe B.
  • JRJ said thank you
#2 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 11, 2013 - 08:29 PM
:welcometogttalk: Welcome carolspain, I am not familiar with the Vanguard engines or the "dashpot" you are referring too. Usually there is a gasket or O-ring between assemblies on any carburetor. Is yours missing? Pictures of the problem would help. I am sure a Deer expert will be along shortly. Again Welcome.
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,798 Thanks
  • 4,292 posts
Posted August 12, 2013 - 03:02 AM
:welcometogttalk:
hi Joe, a photo of the problem will be helpful to locate the leak. maybe it's a gasket, maybe something else...
Edited by jd.rasentrac, August 12, 2013 - 03:03 AM.
  • carolspain said thank you
#4 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted August 12, 2013 - 06:32 AM
Sounds like a gasket.
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 12, 2013 - 06:49 AM
Is the dashpot you are referring to the fuel solenoid? You may be able to seal the leak with a adhesive that's rated for use on gas tanks. I can't think of the name now but there is one brand that's pretty common.
#6 carolspain OFFLINE
carolspain
  • 12 Thanks
  • 14 posts
Posted August 14, 2013 - 10:42 PM
I'll post pic soon. Many thanks for suggestions
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,798 Thanks
  • 4,292 posts
Posted August 15, 2013 - 12:04 AM
sadly I've only found the german product information Attached File  359-TUNAP-TUN-Sil-Gasket-PI.pdf   196.77KB   35 downloads
