Hydro filter blows gasket
81 replies to this topic
#61 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted May 10, 2011 - 01:26 PM
Could there be any chance that this allen plug was screwed in ? Might have been weeping around the threads and tighten by mistake to keep it from leaking ?[ATTACH=CONFIG]14483[/ATTACH]
Hi ALC,
I cant place where this assy is on the machine? Is it internal to the trans? Where can I find the Allen screw? I am the only monkey working on this and I did not touch it. I will check it out if I can find it.
Many thanks
#62 ducky OFFLINE
  • 2375 Thanks
  • 4342 posts
Posted May 10, 2011 - 01:31 PM
Is the Eaton on the 16 same as the 17? If I pull plug 56 and 39, do i need to drain fluid? Is there a lot of tension on the spring? It is also hard to see exactly where it is in the pic. I will check it out tonight.
Thank-you!
Woo, I am getting confused. Is this an Eaton or a Sundstrand hydro. I see both being mentioned here. Sundstrand has the charge pump draw oil from the reservoir thru the filter and eaton return the oil back thru the filter.
#63 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted May 10, 2011 - 01:40 PM
This is an Eaton Ducky.
#64 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted May 10, 2011 - 01:42 PM
ducky I hope it's a Eaton because that it was !!!
#65 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted May 10, 2011 - 01:43 PM
Thought it was an Eaton
#66 ducky OFFLINE
  • 2375 Thanks
  • 4342 posts
Posted May 10, 2011 - 02:15 PM
I could have swore that the parts pages were Sunstrand.
#67 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted May 10, 2011 - 05:07 PM
Just heading out to the garage. I think that is a Sunstrand as my Eaton does not look similar. I have the posted maintenance manuals and I cant seem to find those ports to the relief valve. But I will check the tractor.
Thanks
#68 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted May 10, 2011 - 06:03 PM
OK ALC, I now understand your attachment. I would have to open it up to check that. I know that would be too far down my list. I may run it just to see how long a filter with a bypass will hold out for. I have two others so this one may become parts. Sad thing is it is in perfect shape and runs great. Just the filters blowing apart is a bit of an issue.
#69 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted May 10, 2011 - 08:08 PM
Your right I was looking at the plug on the side , the relief screw is inside , I wouldn't think it would screw in on it's own , maybe plugged ? Don't give up !!
#70 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted May 11, 2011 - 09:17 AM
Ha Ha! Thanks for the kick in the ass. If I cant get those woodruff keys out of the axle on my other unit, I may be pulling the rearend on this one anyways. Then I might as well go inside! Well, one out of three machines running is not really bad.... : (
#71 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted May 12, 2011 - 05:36 AM
Wish I could be more help. I've only run into your problem once and it was my fault . I installed a engine oil pump rebuild kit in my Ford 3400 and the new relief valve had a solid plug cap , the old one had a small hole in it . Well that hole was for the exessive oil to flow back into the pan . As soon as I started the engine the oil filter puffed up and leaked .:wallbanging::wallbanging:
#72 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted May 12, 2011 - 09:03 AM
I have a pic or two to share but for some reason on this site I have issues. When the pick computer or URL comes up, I can get no further. If I go to the advanced, the pic manager screen is just gray.
Appreciate all the assistance!
#73 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted May 12, 2011 - 07:09 PM
Are you uploading from your computer or one of those image hosting sites?
#74 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted May 13, 2011 - 09:46 AM
Hi Dr.Bolens,
Right off my desktop.
Bobo
#75 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted May 13, 2011 - 10:03 AM
When I select computer, the bottom of the window does not expand to choose location.
