Hydro filter blows gasket
81 replies to this topic
#31 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted November 29, 2010 - 08:17 AM
Yep, it was coming out like a garden hose! Dont have to worry about rust underneath now. Everything got a few real good coats. On the sunny side, if it was not the winter, I would have not known soon enough and would probably have burned out the pump. Was surprised how far the single stage throws IF there is a good amount of snow. No worries with that up here!
Stay warm!
#32 massey driver OFFLINE
massey driver
  • 1550 Thanks
  • 1613 posts
Posted November 29, 2010 - 08:40 AM
What??? did the filter gasket blow out again.or are you reffering to before.Clarify please.What to know if its still giving you problems..Larry
Edited by olcowhand, November 29, 2010 - 09:24 AM.
repaired quote
#33 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted November 29, 2010 - 02:00 PM
Hi Larry,
My one run was successful. All good so far. Is 50 psi common on the low pressure side? Nice rig you have there!
#34 massey driver OFFLINE
massey driver
  • 1550 Thanks
  • 1613 posts
Posted November 29, 2010 - 03:27 PM
Hi Larry,
Glad that it'still working for you,looks like we'll get to blow more tonight and tommoro.Roads were pretty terrible comming home from Wpg.this afternoon.Sure it's going to be way worse tonight.As for the psi not familiar with Bolens would have to check there manuals.BTW when you blow snow again with it let us know if everything goes smoothly with thw Hydro filter.Larry
#35 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted February 16, 2011 - 08:04 AM
Hello Everyone!
It has been a few months and not much has changed....except for the size of my hydro filter! I obviously have not repaired my filter issue as I found the other day when the cup wrench would not fit as the bottom is round. Yep, the pressure is so high it has deformed the filter. Unit works great but I have something bad going on. YIKES! On the other hand I have purchased another QT17. This one will be Fido 3.
Cheers
#36 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted February 16, 2011 - 12:45 PM
sorry to hear you are still having troubles.....
I'm no help in this case :(
#37 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted February 16, 2011 - 09:20 PM
Sorry to hear the problem is still there , I couldn't find a service manual for your Eaton hydo unit , maybe if we had one that showing a fluid flow chart someone might be able to help you. ( found just the tractor manual )
#38 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted February 22, 2011 - 02:42 PM
Yep a flow diagram would be great. I have an Eaton manual but it is less than helpful. Maybe I will see something in the spring.
Thanks!
#39 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted February 23, 2011 - 07:44 PM
I found some info on the Eaton site and uploaded it. Looks like it might help you when you troubleshoot the filter problem , Al
  • Bolens 1000 said thank you
#40 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted February 23, 2011 - 07:51 PM
Thanks Al
I'll add the link here :thumbs:
Eaton 6, 7and 11 - Manuals - Garden Tractor Talk - Forums
#41 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted February 23, 2011 - 08:47 PM
Just loaded the Eaton Model 11 service manual
Eaton Model 11 Service - Manuals - Garden Tractor Talk - Forums
  • ducky and MH81 have said thanks
#42 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted February 24, 2011 - 08:04 AM
Excellent and thanks! But I cant seem to download them. Seems the file is empty. Let me ttry a few things.
#43 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted February 24, 2011 - 08:20 AM
I downloaded it here, took all of about 4 seconds. Nice manual.
#44 Bobo OFFLINE
Bobo
  • 8 Thanks
  • 99 posts
Posted February 24, 2011 - 12:11 PM
I will try tomorrow as I am at the limit for today.
Thanks
#45 EricFromPa OFFLINE
EricFromPa
    Fixer of Broken junk
  • 6875 Thanks
  • 4608 posts
Posted February 26, 2011 - 09:02 PM
You need Adobe Reader to open the manuals.
http://get.adobe.com/reader/
You might want to check the return line on the filter.
It could of got crushed or kinked part way shut.
If the Filters return line is crushed shut it will blow filters before the line blows.
I would check all of your lines (hard and soft lines).The pump sounds like it's working correctly but you have a blockage somewhere in the return from the filter.
Or the fram filter may have blew chunks into the return line.
I've had a couple Fram filters on cars that were defective.They acted like they were clogged up.WIX is my brand of choice for filters ever sense.
Edited by EricFromPa, February 26, 2011 - 09:31 PM.
