Jb Diesel Rear Pto
65 replies to this topic
#46 olcowhand ONLINE
  • 43,157 Thanks
  • 32,008 posts
Posted March 06, 2014 - 07:05 PM
After getting calf feed ground & other chores wrapped up, I spent some time on the pto.  All is bolted up & fully operational!  Using my photo tach, I checked the pto output speed. When the engine is at 2400rpm, the pto is turning 2,000.  The diesel is sounding plenty busy at that speed, so I'm sure there will be MORE than enough power for anything I'm doing with the pto.  2400 to 2500 rpm is the top of the peak torque curve anyway.
  I still have some braces I will be adding to strengthen the rear plate, but no rush on doing that.  I still have to run wiring for the pto & add a switch.  Now that I'm so close to being able to till with this tractor, the ground will be wet to China for weeks!
  Battery was almost dead in the camera, so pics & video sometime tomorrow.  Kind of tired, so not going back to the shop tonight.
  • coldone, KennyP, sacsr and 2 others have said thanks
#47 olcowhand ONLINE
  • 43,157 Thanks
  • 32,008 posts
Posted March 07, 2014 - 10:49 AM
Got a couple pics this morning, and video is uploading as I type.  Man do I wish I could try my tiller with this, but it'll be a few weeks before the ground gets anywhere near dry enough.  In the meantime I can wrap this pto project up & get the 3 point lift back on.  All is bolted in solid now.
  • KennyP, sacsr, chris m and 1 other said thanks
#48 olcowhand ONLINE
  • 43,157 Thanks
  • 32,008 posts
Posted March 07, 2014 - 11:03 AM
Here's the video.  When showing the JD430 pto shaft on the hydro, I just said "JD430 clutch" when I should have said JD430 clutch SHAFT".  I wan't going to shoot another video on account of that little glitch.
  • coldone, chris m, twostep and 1 other said thanks
#49 KennyP ONLINE
  • 41,474 Thanks
  • 47,403 posts
Posted March 07, 2014 - 12:21 PM
That's great, Daniel. Nothing like the satisfaction of a completed project!
  • olcowhand said thank you
#50 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted March 07, 2014 - 12:28 PM
That is seriously awesome Daniel! You never cease to amaze me! Great job  :thumbs:  :worshippy1:
#51 twostep ONLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted March 07, 2014 - 12:53 PM
Daniel, I admire you ability to "get stuff done"... It would take me weeks to do what you whip in a few days. Looks good and should be handy!
#52 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted March 07, 2014 - 05:48 PM
Thats great Dan! Looked pretty simple and straight forward. Cant wait to see it tilling,
#53 olcowhand ONLINE
  • 43,157 Thanks
  • 32,008 posts
Posted March 08, 2014 - 02:59 PM
Finished wiring a switch to the rear pto.  All is "almost" ready for a real test with the tiller as soon as the ground dries.  I say almost, as now out of the blue, I have an oil leak from the steering orbital valve.  Can't see back in there till I take the battery out.  I might get to that tomorrow.  Hoping it's just a loose fitting.
#54 KennyP ONLINE
  • 41,474 Thanks
  • 47,403 posts
Posted March 08, 2014 - 03:22 PM
Good to hear you're getting more therapy!
#55 olcowhand ONLINE
  • 43,157 Thanks
  • 32,008 posts
Posted March 15, 2014 - 09:47 AM
Plowing my garden with Hogzilla this morning.  Over half done and (I) got too warm, so came in to change out insulated bibs for bluejeans.  Once plowing is finished, then after lunch I'll put the tiller on & test the rear pto a couple passes.
#56 Cat385B ONLINE
    HAZMAT CAT
  • 14,456 Thanks
  • 10,184 posts
Posted March 15, 2014 - 09:53 AM
I thought you meant the tractor overheated, whew. Don't scare us like that. What about the oil leak? Loose fitting, or are you leaving a trail to be able to find the shop again?
#57 olcowhand ONLINE
  • 43,157 Thanks
  • 32,008 posts
Posted March 15, 2014 - 10:00 AM
Well, once the oil leak soaked past the battery tray, I realized it was engine oil.  While running the wiring for the rear pto clutch, I guess I pressed against the plastic oil gauge line too hard & snapped it off.  Just went & got a compression coupling & repaired it.  I'll likely replace the line with copper if I ever get around to it.  I like to run the copper inside vinyl tubing for protection, then you never have any issues.
  • Cat385B said thank you
#58 olcowhand ONLINE
  • 43,157 Thanks
  • 32,008 posts
Posted March 15, 2014 - 01:36 PM
  • DH1, coldone, LPBolens and 5 others have said thanks
#59 KennyP ONLINE
  • 41,474 Thanks
  • 47,403 posts
Posted March 15, 2014 - 02:55 PM
That was great! I think you have a winner there!
#60 DH1 ONLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted March 15, 2014 - 07:31 PM
Looks like it works good, :thumbs:
My garden is snow covered and frozen, you got made down there.
