Jb Diesel Rear Pto
65 replies to this topic
#31 olcowhand OFFLINE
  • 42,408 Thanks
  • 31,803 posts
Posted March 03, 2014 - 06:17 PM
2 o'clock from center of pic, you can see where I welded the rear extension onto the rear plate.  I'll drill the holes once I have everything aligned.  Then a pic of the driven pulley on the gearbox.
Everything is just rigged up so I can get an idea where I am going.
Here is the pto clutch I got off a JD rider I bought at auction.  It's engine had a tossed rod.  Then there is the pillow block bearing that will hold the rear of the pto shaft once I get the shaft extended, and the JD430 rear pto shaft.
And our roads haven't been touched yet, and I heard the main highway to ANYWHERE is a solid sheet of ice & snow as well.
  Be careful Kenny not to turn that T into a crossroad!
  • KennyP and sacsr have said thanks
#32 KennyP ONLINE
  • 40,138 Thanks
  • 46,771 posts
Posted March 03, 2014 - 06:40 PM
Pto is looking good! I'm not going anywhere until tomorrow. Should get better then!
  • olcowhand said thank you
#33 olcowhand OFFLINE
  • 42,408 Thanks
  • 31,803 posts
Posted March 04, 2014 - 06:55 PM
Got my clutch shaft extended & keyway machined.  This morning I extended the angle iron on both sides from the differential mounts the 2 1/2" as I did the rear plate.  You can see the angled pieces welded in at the bottom.
Things are just mocked up at this point, but all looks like it should work perfectly.  Once I get everything aligned just right, then I'll drill the mounting holes for everything.  I will be using a spring loaded tensioner on the belt so no adjusting will be needed.  Also, I plan to add a tension release lock on the pto tensioner so when not using the pto, I can unload the tensioner pressure to extend life of bearings/etc.
  • KennyP, sacsr and twostep have said thanks
#34 olcowhand OFFLINE
  • 42,408 Thanks
  • 31,803 posts
Posted March 04, 2014 - 07:09 PM
My total, unless I have some sort of nasty surprise arise, should be right at $400 to add this rear pto.  Well worth it to me!
  • Texas Deere and Horse and sacsr have said thanks
#35 KennyP ONLINE
  • 40,138 Thanks
  • 46,771 posts
Looks real good, Daniel! Bet your having a blast with this!
#36 olcowhand OFFLINE
  • 42,408 Thanks
  • 31,803 posts
Posted March 04, 2014 - 07:13 PM
Yes, with all the stress I've had the last several months, I AM so enjoying this!  Looks like I'll be using Hogzilla to till the garden come spring....whenever it dries up that is.
#37 KennyP ONLINE
  • 40,138 Thanks
  • 46,771 posts
Posted March 04, 2014 - 07:28 PM
That's great! You've needed a bit of therapy for some time now!
#38 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted March 04, 2014 - 10:46 PM
Is it going to be 2000rpm?
#39 olcowhand OFFLINE
  • 42,408 Thanks
  • 31,803 posts
Posted March 05, 2014 - 08:28 AM
Yes, with the engine at 2500rpm, the pto will be 2,000rpm.  That engine speed is close to the max torque.  Really around 2,600rpm engine speed is ideal, but when I originally ordered my pulleys, I wasn't going with this electric clutch, which has a larger pulley.
  • coldone said thank you
#40 olcowhand OFFLINE
  • 42,408 Thanks
  • 31,803 posts
Posted March 05, 2014 - 05:42 PM
Machined a spacer this morning to go between the clutch bearing & the pillow block bearing, then drilled & tapped the end of the shaft at the pillow block end of shaft for a retaining bolt/washer to keep the shaft in place so it can't walk back against the hydro housing.  Temporarily clamped down the pillow block to the rear plate & fired up the engine.  The shaft runs smooth, so all is looking great at this point.  A couple weeks or less and I should have the pto finished.
#41 KennyP ONLINE
  • 40,138 Thanks
  • 46,771 posts
Posted March 05, 2014 - 05:48 PM
Now, whatcha gonna use it fer?
#42 olcowhand OFFLINE
  • 42,408 Thanks
  • 31,803 posts
Posted March 05, 2014 - 06:00 PM
It's gonna be my "go to" tractor for garden work, plowing, and tilling.  The diesel is so reliable, so I wanted it to run the tiller.  Seemed every time I go to till, I end up with carb/fuel issues on the gassers.
#43 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,109 posts
Posted March 05, 2014 - 06:51 PM
When I haul the Allis back to Mn, will there be a gas engine left on the place?
#44 KennyP ONLINE
  • 40,138 Thanks
  • 46,771 posts
Posted March 05, 2014 - 07:06 PM
Stay gone a bit longer & I'll have them all cleared out!
#45 olcowhand OFFLINE
  • 42,408 Thanks
  • 31,803 posts
Posted March 05, 2014 - 07:25 PM
When ya buying the Allis?  It is going up for sale soon.  As far as workers, I'll still have the modified MF1650 that I call a "2055", other than that, all the gassers are my collection of Bush Hogs and my MF12H.
  • sacsr and twostep have said thanks
