Shaw Headlights
  • This topic is locked This topic is locked
22 replies to this topic
#1 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted August 09, 2013 - 04:05 PM
After mounting headlights on the R/T tractor, I decided to make up a set for the Shaw tractor as well.
Here is what the front of the Shaw tractor looks like now.
Rummaging thru my junk I came across an old pair of lights with home made brackets that would be just the right vintage to go with the Shaw tractor.
These were fog lights on a 1946 Plymouth that I had back in the late 60's.
The outside ring on one of them was cracked so I welded it up.
Here is how it looks with the weld ground down.
The home made mounting brackets are bent up so I need to straighten them in the press.
The end is clamped in the vice so I can hammer the top of the bracket over to the correct angle.
With that done on both brackets, I realized that one bracket sets higher and is longer than the other bracket.
The top bend on the longer bracket is flattened out on the press.
The top of the bracket is re-bent so now the two brackets are the same height.
The hole in the modified bracket is welded up.
Then it is ground down smooth.
The longer end is cut off the modified bracket and a new mounting hole is drilled into it.
The mounting stud on the headlights is 5/16 and the holes in the brackets were 1/2 inch.
The new drilled hole is 5/16 and I made up a bushing to reduce the hole down to size in the other bracket.
All the parts are sandblasted, primed and painted.
I found an old pull out light switch that looks like it is right out of the 30's or 40's to use on the tractor.
  • Gtractor, MH81, Texas Deere and Horse and 7 others have said thanks
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,295 Thanks
  • 9,779 posts
Posted August 09, 2013 - 04:27 PM
What color of paint is that? I like the colors of the old industrial paints.
  • jdcrawler and hamman have said thanks
#3 TomLGT195 OFFLINE
TomLGT195
  • 3,829 Thanks
  • 2,814 posts
Posted August 09, 2013 - 05:03 PM
man the suspense is killing me. I need to see the final product. I think that's an awesome looking tractor already.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted August 09, 2013 - 05:13 PM
You are one talented guy.
Ben W.
  • jdcrawler said thank you
#5 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted August 09, 2013 - 05:14 PM
I don't think I will watch the rest of this thread. I want to be surprised next week when I see it in person. lol. As always great work. Roger.
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,295 Thanks
  • 9,779 posts
Posted August 09, 2013 - 05:39 PM
Yes Roger! Rub it in!!!
  • hamman said thank you
#7 hamman ONLINE
hamman
  • 6,436 Thanks
  • 2,860 posts
Posted August 09, 2013 - 05:42 PM
I promise LillysDad I will take lots of pictures. Maybe Ray will let me get one of him and I also. Roger.
#8 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted August 09, 2013 - 06:40 PM
You have been busy!
Thanks for the photos of your work......But we need to see the final results!
That is a neat looking tractor.
#9 Sawdust ONLINE
Sawdust
  • 5,657 Thanks
  • 3,370 posts
Posted August 09, 2013 - 06:59 PM
Fantastic ! I'm enjoying the suspense. Your tractor is sitting so proud looking....did it have any sheet metal on it originally?
#10 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted August 09, 2013 - 07:23 PM
Rust-oleum dark hunter green
No ..  originally it was a two wheel walk behind garden tractor that was converted into riding tractor.
#11 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 09, 2013 - 07:27 PM
Looking good, That is one nice machine! :bounce:  What size are the housings? Will you be able to find replacement bulbs to fit?
#12 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted August 09, 2013 - 09:19 PM
These take a standard 4-1/2 inch sealed beam tractor light bulb.
I went to TSC this evening and picked up two bulbs.
#13 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted August 09, 2013 - 09:23 PM
What day are comeing I maybe there aswell?
#14 hamman ONLINE
hamman
  • 6,436 Thanks
  • 2,860 posts
Posted August 09, 2013 - 09:52 PM
We will be there on Friday am until ? Hope to see you there wilberj.      Roger.
#15 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted August 10, 2013 - 03:11 PM
This little tractor has an unusual clearance restriction on the front that you don't normally find on a garden tractors this size.
The engine on this tractor has a flat belt pulley on the side for running a bus saw, corn sheller, cream separator and other farm equipment like that.
I need to make sure the headlights aren't in the way of  a belt coming off that pulley.
The mounting brackets for the headlights are bolted to the frame to keep both headlights close together in the center.
With the headlights all mounted, here is what the tractor looks like now.
With the headlights on.
The wiring runs across the top of the frame and under the engine.
  • olcowhand, Texas Deere and Horse, wvbuzzmaster and 2 others have said thanks
