Kohler K321 Ring Positioning
7 replies to this topic
#1 jdslednut OFFLINE
jdslednut
  • 672 Thanks
  • 843 posts
Posted August 08, 2013 - 06:15 PM
Got my block back from the machine shop and want to put my Kohler back together.  The rings that came with my aftermarket kit are different than the ones on the example sheet provided.  All of the top rings show a chamfer but mine is square.  Top and middle rings are different thicknesses so I know which goes where.  For those of you who has installed kits, are these normally square?  I have an email in to the supplier but I want to get going on the assembly.
  • JRJ said thank you
#2 boyscout862 ONLINE
  • 10,367 Thanks
  • 7,843 posts
Posted August 08, 2013 - 06:35 PM
Try the manuals section. Good Luck, Rick
#3 gopher OFFLINE
gopher
  • 604 Thanks
  • 659 posts
Posted August 08, 2013 - 07:26 PM
The top compression ring can be ether square or beveled.if punch marked or etched goes up . Otherwise doesn't matter orientation.
  • chris m said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted August 08, 2013 - 07:33 PM
Square rings are common replacements for beveled.  Most aftermarket parts companies do that.  Cut costs where you can is the motto, I guess.  Sometimes I think square rings give better compression, too, but I can't prove that for certain.
Ben W.
#5 Guest_gravely-power_*
  • Guests
Posted August 08, 2013 - 07:49 PM
Beveled, etched, or"pip" mark goes up. If square, it makes no diff.
#6 lyall OFFLINE
lyall
  • 1,807 Thanks
  • 1,428 posts
Posted August 09, 2013 - 09:05 PM
so now you know how to install the rings
after you have the rings on the piston now to align the ring gap
set the top ring then the middle ring should be set at 120 degrees then the oil rings at 120 degrees to the middle ring
but I set my rings different
set the top ring then the middle ring goes at 180 then if it is one piece oil ring I set it 180 degrees to the middle ring
if the oil ring is a 3 piece then I set the top oil ring 90 degrees to the middle ring and the bottom oil ring is set 180 degrees to the top oil ring
#7 olcowhand ONLINE
  • 36,519 Thanks
  • 30,072 posts
Posted August 09, 2013 - 09:29 PM
I set my rings as you do lyall.  Always have & always will.  Just makes sense having the longest path possible between gaps.  Main thing is not to have any gap inline with the crank, or 90 degrees from that.
  • lyall said thank you
#8 jdslednut ONLINE
jdslednut
  • 672 Thanks
  • 843 posts
Posted August 09, 2013 - 10:07 PM
I've always done the same.  I spoke to a Briggs educator that said it didn't really matter because they rotate while running.  It's still piece of mind for me to stagger them.
