R/t Tractor Headlights
35 replies to this topic
#1 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,182 Thanks
  • 1,728 posts
Posted August 08, 2013 - 01:25 PM
Some time ago I had thought of putting headlights on the R/T tractor but hadn't made up my mind on just where to mount them.
The most logical place for them was up front on the side of the grille.
At the time I was really hesitant to drill into the fresh paint job on the hood so I keep putting it off and eventually just forgot about.
Today I was washing the tractors to get ready for the show and decided to finally mount those lights on the tractor.
Here is how the tractor looked before.
These are the headlights that I had bought for the tractor.
They are going to be mounted on the side of the grille and down low enough so the don't block the "R/T" emblems.
First I put masking tape on the side to protect the paint and give me a surface to mark locations on.
Then I drilled out the mounting hole and the hole for the wire.
The front hole is for mounting the headlight and the rear hole has a rubber grommet for running the wire thru.
The mounting bracket on the headlights have a square base so I'm going to use a washer between the headlight and the grille so the square base doesn't scratch the paint when the headlight is rotated to adjust it.
I stick the back of the washers onto a piece of masking tape.
The tape is trimmed off around the washer and the tape side goes up against the side of the grille.
The tape on the back of the washer keeps the washer from scratching the paint.
This also provides enough resistance so the headlight can rotate on the face of the washer and the washer will not rotate against the painted surface.
The wires are run down the inside of the grille and connected to the wire from the switch with disconnect terminals.
This way the wires can be easily disconnected if I want to remove the grille.
Here is how the headlight looks from the back.
And from the front.
They even work !
Edited by jdcrawler, August 08, 2013 - 01:42 PM.
  • wilberj, powerking56, Gtractor and 14 others have said thanks
#2 twostep ONLINE
twostep
    Rockstar
  • 1,856 Thanks
  • 2,484 posts
Posted August 08, 2013 - 01:46 PM
Those look really good on there Ray! I have loved this tractor since the first time I saw it. I even bid on it...
  • jdcrawler and hamman have said thanks
#3 UncleWillie ONLINE
  • 12,995 Thanks
  • 7,785 posts
Posted August 08, 2013 - 01:48 PM
I always thought the R/T needed eyes. Looks great on there.
  • jdcrawler, hamman and Sawdust have said thanks
#4 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,182 Thanks
  • 1,728 posts
Posted August 08, 2013 - 01:50 PM
As it has turned out, I'm glad you didn't bid more or you would own it now instead of me !
  • hamman and twostep have said thanks
#5 twostep ONLINE
twostep
    Rockstar
  • 1,856 Thanks
  • 2,484 posts
Posted August 08, 2013 - 02:03 PM
haha, I typed in as much I could afford and it just wasn't enough.
#6 UncleWillie ONLINE
  • 12,995 Thanks
  • 7,785 posts
Posted August 08, 2013 - 02:11 PM
I wish you had of bought it so it would be closer to me when I come to steal it. LOL
  • hamman said thank you
#7 wvbuzzmaster OFFLINE
  • 4,496 Thanks
  • 7,343 posts
Posted August 08, 2013 - 02:20 PM
Ray, I didnt know of the tape on the washer trick. That will come in handy later.
#8 JD DANNELS OFFLINE
JD DANNELS
  • 3,786 Thanks
  • 3,907 posts
Posted August 08, 2013 - 02:22 PM
Just as expected, Ray your usual meticulous detailed work.  The lights look great and give the R/T a finished look.
#9 LilysDad ONLINE
LilysDad
    Crazy about GTTalk
  • 10,056 Thanks
  • 7,907 posts
Posted August 08, 2013 - 02:26 PM
Ray, you can even drill a hole better than anyone I know!!!
#10 wilberj OFFLINE
wilberj
  • 4,366 Thanks
  • 5,271 posts
Posted August 08, 2013 - 03:02 PM
Looks great Ray! Hope I can make it up to see her!
Edited by wilberj, August 08, 2013 - 03:03 PM.
  • jdcrawler said thank you
#11 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 5,721 Thanks
  • 2,618 posts
Posted August 08, 2013 - 03:03 PM
Looking forward to getting more pics of the R/T and your other tractors next week Ray. Roger.
#12 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,182 Thanks
  • 1,728 posts
Posted August 08, 2013 - 03:06 PM
I'm glad you guys like the look of the tractor with the lights on it.
Now that it's done, I wonder why I waited so long to put them on ?????
Next I think I need to come up with an old headlight setup for the Shaw tractor.
To make it look right, I'll need some lights from the 30's or 40's though.
Edited by jdcrawler, August 08, 2013 - 03:10 PM.
  • wilberj, MH81 and hamman have said thanks
#13 wilberj OFFLINE
wilberj
  • 4,366 Thanks
  • 5,271 posts
Posted August 08, 2013 - 03:07 PM
Do you ever drive it in the dark? :D
#14 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,182 Thanks
  • 1,728 posts
Posted August 08, 2013 - 04:44 PM
Actually, yes I have and I had wished it had lights then.
#15 MH81 ONLINE
  • 27,983 Thanks
  • 28,940 posts
Posted August 08, 2013 - 05:14 PM
Ray, they do look nice... Why DID you wait so long? :D
What diameter are you looking for in the headlights?
