In Need Of A Elect Schematic For A Mid 70's Jd 110
6 replies to this topic
#1 york0060 OFFLINE
york0060
  • 309 Thanks
  • 146 posts
Posted August 08, 2013 - 08:55 AM
My son and i are working on his 74 John Deere 110 and it has elect issues. It will only run if you keep the key in the start position, as soon as you switch to run position its dies. Any help would be great.
Thanks guys
#2 JDBrian OFFLINE
  • 9,606 Thanks
  • 14,142 posts
Posted August 08, 2013 - 10:10 AM
Do you have a ser. no. The manuals tend to breakdown by ser. no. rather than year.
#3 york0060 OFFLINE
york0060
  • 309 Thanks
  • 146 posts
Posted August 08, 2013 - 10:31 AM
Serial Number 335039M
Type TO631
#4 HDWildBill OFFLINE
  • 8,975 Thanks
Posted August 08, 2013 - 11:40 AM
Here is the manual for an L110.  But that doesn't help here is a list of manuals for JD 110 products see one of these will work.
#5 JDBrian OFFLINE
  • 9,606 Thanks
  • 14,142 posts
Posted August 08, 2013 - 06:58 PM
I don't have anything for a 110 in the serial no. range. You likely have a problem with your ignition switch.
  • york0060 said thank you
#6 york0060 OFFLINE
york0060
  • 309 Thanks
  • 146 posts
Posted August 09, 2013 - 08:37 AM
At last it runs!  It needed a new ign. switch.  I think the switch went out on the previous owner and he must have moved the wires around to try to get it to run, but after some time spent with my volt meter i figured it out and bought a new switch and it runs. No smoke at all and sounds really great.
#7 HDWildBill OFFLINE
  • 8,975 Thanks
Posted August 09, 2013 - 09:33 AM
I was with Brian and figured it was the switch.  Glad you got it figured out and have it running. :thumbs:
