Hf Polycarbide 4.5" Abrasive Wheel
paint removal rust removal
1 reply to this topic
#1 framesteer OFFLINE
framesteer
  • 530 Thanks
  • 254 posts
Posted August 07, 2013 - 09:27 PM
I'm new tp watching this Tool Shed topic, so apologize if this has been discussed before.
During my restoration on my Bolens Lawn Keeper, my son told me about this product.
Neither of us have a sandblaster, so he saw people at his workplace using abrasive wheels similar to these a HF (HF# 94017).
The work these inexpensive wheels will do is amazing - in my opinion a cheap substitute for a sand blaster.  They cleanly remove paint without damaging the surface of the sheet metal, as well as rust-pitted surfaces.  You will have to get out the grinding disks to smooth out heavily pitted surfaces (same thing for most sandblasters).  After using these wheels, the surface will appear to have "grinding" marks, but the surface is not damaged in any way, and is ready for primer.
If you have tight bends or restricted access, the sandblaster is what you need.
  • Alc and Arti have said thanks
#2 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted August 07, 2013 - 10:02 PM
We used the same type disk at work, just a name brand one. They work great for stripping paint! You just don't want to hit an edge or anything as they will loose there life quick!
