New At Tractor Pulling
pulling forum
8 replies to this topic
#1 old149 OFFLINE
old149
  • 38 Thanks
  • 21 posts
Posted August 07, 2013 - 07:05 PM
has anyone used a gilson 16 hp single flat head
old149
  • Dieselcubmike and OkieGt have said thanks
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted August 07, 2013 - 07:47 PM
There was a kid that pulled in the kids class years ago that was the last time ive seen one of these. It didn't do too bad.
  • OkieGt said thank you
#3 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 07, 2013 - 08:45 PM
They were great pullers in the geared version, they used the long stroking B&S 16hp cast iron synchro balanced engine
#4 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted August 07, 2013 - 11:04 PM
Here is the one I pull with:
I had to install a different engine because when I got mine the engine was removed except for the oil pan because it was the pivot for the front axle. I have a 16hp 2cyl Briggs and Stratton engine in it.
What I changed for pulling it:
I added a pilot bearing half way down the length of the drive shaft. The length of the drive shaft is too long that the torque of pulling will make it warp and go out of balance.
I added a second spring to the clutch belt pulley tightener, and make sure that belt is a black color belt. They have the most grip.
Other wise it is all original.
#5 Cheetah OFFLINE
Cheetah
  • 57 Thanks
  • 57 posts
Posted August 13, 2013 - 11:34 AM
That should be a good tractor for the stock class.
Not sure about those tires though, especially if the club you're puling with allows Ag tires.
If they require turf tires, you'll have a better chance, but usually the Carlisle Turf Masters are the ones to have...
#6 slufkin OFFLINE
slufkin
  • 5 Thanks
  • 5 posts
Posted August 16, 2013 - 07:51 AM
My son has the Montgomery Ward version of that tractor, but it has been pretty heavily modified. It now has a Kohler Command V-twin and a Cub Cadet Transaxle. I am a new member and I am not sure how to put up a picture. If I can figure it out I will get you one.
#7 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted August 16, 2013 - 08:12 AM
slufkin we gonna see you this weekend @ Sunny creast and Thursday @Wash Co ?
#8 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 16, 2013 - 01:22 PM
On the reply box below click on more options that wlll show you a "browse"  dialouge box that you can search ypur files, once you click on the picture ypu want click "open" then choose attach fille button, then "add to post" button on the right
#9 slufkin OFFLINE
slufkin
  • 5 Thanks
  • 5 posts
Posted August 19, 2013 - 09:31 AM
There we go.
Thanks for the help.
Anyways, here is my sons tractor, as I said it is a Cub Cadet rear-end and a Kohler Command now. We also added the side panels, they are custom, not any originals available that I know of.
Bearpath, we couldn't make it to Sunnycrest, but we will be at Washington County for sure.IMG_0945.JPG
