Briggs And Stratton Fuel Pump Nipple
fuel pump
4 replies to this topic
#1 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted August 07, 2013 - 08:30 AM
The vacuum activated fuel pump on my JD 111 is leaking at the plastic outflow nipple. I replaced the diaphrams and hoses and then found this problem. None of my manuals cover this. Is it a pressfit? Can I get a replacement? It looks very similar to the plastic nipple on one of my AC B10 carbs. Thanks, Rick
#2 HDWildBill OFFLINE
  • 8,975 Thanks
Posted August 07, 2013 - 09:14 AM
I have some nipples from a Kohler pump.  They kind of snap in.  I'll take some Pic's later today and post them to see if you can use them.
#3 HDWildBill OFFLINE
  • 8,975 Thanks
Posted August 07, 2013 - 12:35 PM
Rick, here are some Pic's of the nipples I was telling you about.  If you think you can use them let me know.
#4 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted August 07, 2013 - 01:38 PM
I'll pull the old one out to see but I'm not sure if its press fit or the threads are stipped. Thanks, Rick
#5 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted September 09, 2013 - 03:45 PM
I ended up epoxying the old nipple.
Also tagged with one or more of these keywords: fuel pump
