Wanted
1970 Commando V8 Transaxle
6 replies to this topic
#1 geo OFFLINE
geo
  • 3 Thanks
  • 16 posts
Posted August 06, 2013 - 04:38 PM
Hi All, I have a 1970 Commando V8 with a bad transaxle. Tore it down today and found a destroyed ring and pinion. Any help would really be appreciated. Model# 1-4851 serial#714383 trans #5066. Ring gear #7952-looks like that may be the number for the whole differential, pinion #7994.
Thanks George from MI.
  • JRJ said thank you
#2 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted August 06, 2013 - 05:00 PM
This is in a 1982 service bulletin #325
1.1 The differential assemblies used on the above model tractors are obsolete and no longer
available. However, a quantity of the differential face gear has been specially machined from
steel to satisfy customer demand.
1.2 Since the differential was always serviced as an assembly, NO OTHER PARTS ARE
AVAILABLE. If differential parts other than the face gear are required, the unit is not
repairable.
1.3 Be sure to consult the Parts Price List before ordering the face gear, as it is relatively
expensive. Also check the Price List for availability of other transaxle parts required.
2.1 The replacement face gear is our P/N 105176. Be sure to examine the pinion, P/N 7953,
very carefully. It should be replaced if ANY damage is noted; otherwise, the new face gear
may be ruined.
P/N 7952, 100173, 100204 Used on
Charger V8 models 1-7841, 1-7851
Commando V8 models 1-4841, 1-4851, 1-4852
Charger V7 models 1-7741, 1-7751
Commando V7 models 1-4741, 1-4751, 1-4752,
CG-7 models 1-0270, 1-0275
CG-8 models 1-0200, 1-0201, 1-7752
8HP 4-Speed models 1-0276, 1-0277
Good luck
Garry
Edited by GWest, August 06, 2013 - 05:04 PM.
#3 geo OFFLINE
geo
  • 3 Thanks
  • 16 posts
Posted August 06, 2013 - 07:36 PM
need ring and pinion for this commando vertical drive transmisson #5066
#4 geo OFFLINE
geo
  • 3 Thanks
  • 16 posts
Posted August 06, 2013 - 07:49 PM
Hi Gary,  I will need the face gear and pinion.  Face gear is shot and the pinion is not far behind.  This is my Grandson's pulling tractor and I've already sunk a lot of money the motor and tires.  Where would I find a price list and availibility?
Thanks George
#5 MH81 OFFLINE
Posted August 06, 2013 - 08:36 PM
Thanks George
If I were you, I would try contacting the site sponsors directly. They would be a good first step.
PS, I moved this into the Classifieds section as that's really what it is becoming and it will have a better chance of traffic there.
  • geo said thank you
#6 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted August 07, 2013 - 05:52 AM
Thanks George
This site will show availability. Enter a part number and if it comes up priced you just got lucky.
http://www.partstree.com/parts/
Garry
#7 dodge trucker OFFLINE
dodge trucker
  • 2,295 Thanks
  • 3,013 posts
Posted September 22, 2013 - 06:00 PM
was just lookin thru the scrap yard section and someone had a commando V8 transaxle for free... don't remember how recent the ad was though
