Fuel Tank Fix?
7 replies to this topic
#1 fishingbud OFFLINE
fishingbud
  • 41 Thanks
  • 64 posts
Posted August 05, 2013 - 10:56 PM
I have an mf7, the fuel tank leaks, groun offall the jb weld and found a 4 inch crack at the bottom. Not a hair line crack, almost looks like a tear. Should i braze, weld, or throw it? I see one on ebay, but 20 bucks and not even sand blasted seems a bit much. Any thoughts?
  • Texas Deere and Horse and JRJ have said thanks
  • 14,730 Thanks
  • 15,470 posts
Posted August 05, 2013 - 10:59 PM
You can cut a patch and solder it in place pretty easily. Just make sure you rinse the tank out good with water before getting close to the tank with a torch.
#3 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted August 06, 2013 - 05:47 AM
 I've soldered my tank with an old large iron using a piece of copper for a patch , I'll see if I can find the thread .
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted August 06, 2013 - 06:25 AM
Brian, I would go farther than that: metal has pores that hold the gas vapors in.  I would take it to a welder and let him fill it with inert gas, and let him blow himself up.
Ben W.
#5 Guest_gravely-power_*
  • Guests
Posted August 06, 2013 - 07:13 AM
I have soldered and/or brazed  dozens of fuel tanks. If you want to braze it, just dry it out and run some exhaust fumes from any tail pipe into the tank and that will render it safe.
#6 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted August 06, 2013 - 07:49 AM
That iron is the trick for a non explosive soldering job on a gas tank.  You don't use a torch.
#7 Alc OFFLINE
  • 6,739 Thanks
  • 7,395 posts
Posted August 06, 2013 - 07:54 AM
Found the thread I made
http://gardentractor...gas-tank-a-try/
  • boyscout862 and robert_p43 have said thanks
#8 fishingbud OFFLINE
fishingbud
  • 41 Thanks
  • 64 posts
Posted August 09, 2013 - 01:04 AM
Well i tried to weld it, but failed....so i broke down and got one off ebay for 20...new is 40 bucks or so....oh well
