Need Help Wth Farmall M Governor
1 reply to this topic
#1 wheelhorse2 OFFLINE
wheelhorse2
  • 4 Thanks
  • 22 posts
Posted August 04, 2013 - 05:17 PM
I have a 1940 Farmall M that needs some new parts in the governor, does anyone know where i could find new pins for the governor weights? So far i have only been able to find the spring, i need the weight hinge pins also, since one of them nearly came out due to it being worn out. Thanks!!!
Edited by wheelhorse2, August 04, 2013 - 05:18 PM.
#2 nbent OFFLINE
nbent
    customizer
  • 673 Thanks
  • 538 posts
Posted August 04, 2013 - 09:44 PM
check caseih.com the pins are part # 45656da spring # is49407dbx i have found they are cheaper and easier to order them right from case they can get just about any part for these old tractors you want on there
