Fel On My Lgt195
finally getting started
80 replies to this topic
#61 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted August 06, 2014 - 06:08 PM
I just read my first post on this thread.  "( only way to ensure a speedy project is to put it in the way)"  :rolling:  :rolling:  :rolling:  :rolling:
I also looked at the date it started. almost a exactly a year, wow!
  • KennyP and trowel have said thanks
#62 KennyP OFFLINE
  • 37,526 Thanks
  • 45,518 posts
Posted August 06, 2014 - 06:19 PM
Good things come to those who procrastinate!
  • TomLGT195 said thank you
#63 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted August 06, 2014 - 07:54 PM
I want to thank everyone on this site for their advice and encouragement through this project . I will post more detailed pics of certain areas over the next few days, as well as videos of it in use. I do remember someone doing a thread on johnson loaders not having enough curl on their bucket when down , I might address that too, stay tuned .
  • sacsr said thank you
#64 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted August 07, 2014 - 06:28 PM
Well I found the leak, apparently I didn't notice this or I would have cut it out when I did the line expansion. here's a pic of the culprit.
I'll buy a new longer line and cut out hole ,reflare and put back together .
  • Rock farmer said thank you
#65 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted August 09, 2014 - 04:21 PM
Hole in line fixed! Made a mini lift/ weight holder to hold my 300# steel plate.
This should be enough weight for now. I didn't want to weld anything on plate because it goes in my pickup in winter.
  • KennyP, skyrydr2, trowel and 1 other said thanks
#66 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 10, 2014 - 05:43 AM
Plus your weight that should do well, be careful of hills though, vertical weight like that goes above the wheels can make it a bit top heavy, even with the wheel weights.
#67 KennyP OFFLINE
  • 37,526 Thanks
  • 45,518 posts
Posted August 10, 2014 - 05:59 AM
Nice counter weight and holder!
  • trowel and TomLGT195 have said thanks
#68 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted August 10, 2014 - 06:00 AM
I'm hoping once i get my wheel weights done i might not need the big weight.  I can put the weight sideways to give it lower center of gravity too.
  • trowel said thank you
#69 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 10, 2014 - 06:11 AM
Tom, i am glad to read this, my fear of tractors rolling over stems from were i live and work on a daily basis, all hills up here.
A few years ago we lost a very helpful and strong willed man on SmokStak when he rolled his tractor, may he rest in peace.
#70 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted August 15, 2014 - 06:23 PM
well, I had to rebuild carb the other day. When I got the tractor, it had stuff in the gas tank, which i cleaned out, however , I didn't do the carb as I should have then. :wallbanging:
So, rebuilt carb, cleaned and adjusted points, and now its running beautiful .
maybe a Video this weekend of it doing some work :camera:
Tom
#71 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted August 31, 2014 - 04:41 PM
Finished the wheel weights! What a difference. Total of 85# per side, 170# total felt better and more in control/ better traction than my temporary 300# on the 3pt .
This is the first piece it fits in the small area of the rim.
This a Ford flywheel sans the outside teeth that gets welded to first piece
The 2 pcs welded together and painted
This part weighs 50# then I added this pipe setup to add up to 2 -35# weightlifting plates, the cap unscrews to load an unload , didn't forget the anti sieze on the cap.
Then the last 2 are the main piece mounted , then with the 35# plate added. I have since turned around so I can grab by the veins, and added a spacer block to keep it tight.
Thanks for reading, Tom
  • skyrydr2 and Cvans have said thanks
#72 Cvans ONLINE
  • 6,468 Thanks
  • 6,059 posts
Posted August 31, 2014 - 04:52 PM
Very nice looking!   :thumbs:
#73 TomLGT195 OFFLINE
TomLGT195
  • 3,700 Thanks
  • 2,763 posts
Posted September 01, 2014 - 03:33 PM
started making a  "earth ripper" , saw one on cub cadet site someone posted for a diff attachment.
so far here is my first of 8 rippers. this pushed my plasma cutter to its limits.
its 5/8" thick going on a 3/8"x 3-1/2"x3-1/2"x 48" angle iron. My thought, reason they are so long, is to mount this on my york rake main beam , to be used in conjunction with the rake to grade a gravel driveway?, so they are about 1-1/2" lower than the tines. For my purpose I will use it solo but ,I like to multi purpose things. You never know when I might need it or  have to sell it!
Thanks Tom
Edited by TomLGT195, September 01, 2014 - 03:37 PM.
#74 KennyP OFFLINE
  • 37,526 Thanks
  • 45,518 posts
Posted September 01, 2014 - 04:53 PM
Gonna have to see you tear up some ground with this!
#75 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted September 01, 2014 - 05:47 PM
Love the wheel weights, nice job.
