Fel On My Lgt195
finally getting started
80 replies to this topic
#16 olcowhand ONLINE
  • 43,153 Thanks
  • 32,007 posts
Posted August 13, 2013 - 06:44 PM
Looks SO much better!   :thumbs:
  • TomLGT195 said thank you
#17 TomLGT195 OFFLINE
TomLGT195
  • 4,097 Thanks
  • 2,926 posts
Posted October 22, 2013 - 05:02 PM
well I finally have gotten some time in the garage to work on the FEL project, and here's where I am now.
this is mock up stage
and here are the parts being  marked, then cut out
after a few holes and a bracket welded on it's ready for install
the cross bar in mock up underneath the supports. this will be cut to length and welded to them and the loader posts will sit on this.
 and the support bolted in
once i get the second one bolted I can mount the cross bar , cut, drill , weld , remove then paint for final installation. then it's time to take it off the jack stands and get the snowblower  mounted and adjusted for winter. so I won't be caught off guard while I'm doing the rest of the project.
Tom
  • olcowhand, KennyP, twostep and 2 others have said thanks
#18 TomLGT195 OFFLINE
TomLGT195
  • 4,097 Thanks
  • 2,926 posts
Posted October 26, 2013 - 04:44 PM
another update, got a few more things done this week
here's the cross member welded on with my helper testing the strength and the tabs to be welded for the uprights to be bolted
here is the dented ,leaking lines I didn't hesitate cutting, the fist cut and the mock-u
the new width gives the hoses clearance at hood, just have to figure out the front support location/mount
and finally , my hand sitting on my knee will be able to run controls as well as the clearance for my foot pedals
next up, finish cross member up front and locating front support bars
Thanks Tom
  • olcowhand, KennyP and Rock farmer have said thanks
#19 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted October 28, 2013 - 01:24 AM
Tom that sure look's great, look,s like you'll be able to move some serious stuff with that.good luck getting it mounted
#20 KennyP ONLINE
  • 41,468 Thanks
  • 47,399 posts
Posted October 28, 2013 - 05:17 AM
It's looking good, Tom!
#21 TomLGT195 OFFLINE
TomLGT195
  • 4,097 Thanks
  • 2,926 posts
Posted November 04, 2013 - 06:30 PM
here's the crossmember before ( bolens mount)
and what is under my Ford
Edited by TomLGT195, November 04, 2013 - 06:31 PM.
  • olcowhand and Rock farmer have said thanks
#22 TomLGT195 OFFLINE
TomLGT195
  • 4,097 Thanks
  • 2,926 posts
Posted January 25, 2014 - 08:05 PM
Well after a brief cold and some wicked cold temps I managed some garage time on the loader project, and here's the progress
Me welding the spacer for the crossmember
The frame attached with new diagonal supports
So now relocate the mounts on the bucket and finish the hydraulics
So that's where I'm at looking good for a spring finish!
Thanks for looking , Tom
  • olcowhand, KennyP, Rock farmer and 1 other said thanks
#23 olcowhand ONLINE
  • 43,153 Thanks
  • 32,007 posts
Posted January 25, 2014 - 08:11 PM
You'll be ready to stack poo soon enough!  Great work!   :thumbs:
  • KennyP and TomLGT195 have said thanks
#24 TomLGT195 OFFLINE
TomLGT195
  • 4,097 Thanks
  • 2,926 posts
Posted February 02, 2014 - 04:14 PM
well here is the latest pics, all that's left is rebuilding the front hydraulic lines and mounting the pump
the mounts relocated and the top angle iron was added to mount a hook in future
a quick coat of paint (rustoleum satin) after a wire cup cleaning (didn't do inside figuring it would wear off pretty quick)
thanks for looking, Tom
  • olcowhand, MH81, KennyP and 1 other said thanks
#25 MH81 OFFLINE
  • 29,979 Thanks
Posted February 02, 2014 - 04:20 PM
Nice job. I like satin finish.
#26 KennyP ONLINE
  • 41,468 Thanks
  • 47,399 posts
Posted February 02, 2014 - 04:24 PM
Looks real good, Tom! Be watching for the in use pics!
#27 TomLGT195 OFFLINE
TomLGT195
  • 4,097 Thanks
  • 2,926 posts
Posted March 16, 2014 - 07:27 PM
Finally got hydraulic lines done on crossmember , here's the pic.
Pump is only thing left now.
Edited by TomLGT195, March 16, 2014 - 07:28 PM.
  • KennyP and Rock farmer have said thanks
#28 stiemmy OFFLINE
stiemmy
  • 2,538 Thanks
  • 1,830 posts
Posted March 16, 2014 - 09:04 PM
When you get bored with the Heafty ford (compared to my wimpy, wimpy, wimpy jakes) PM me for shipping directions!! LOL
J/k. Super sweeeet runner you got. Bet the next door neibors lil pee pee stamped cub ca scrap looks like a Yugo parked next to a USA made 1 ton pickup. (TRACTOR). Very nice!!!!
#29 Firemang OFFLINE
Firemang
  • 187 Thanks
  • 197 posts
Posted March 20, 2014 - 01:28 AM
Lookin dang good, you'll be movin dirt and rock in no time!
#30 TomLGT195 OFFLINE
TomLGT195
  • 4,097 Thanks
  • 2,926 posts
Posted June 15, 2014 - 05:02 PM
finally got back to loader project sat nite, apparently you have to take body sheet metal off to get driveshaft out! :wallbanging:
so now that body panel is off i might as well paint it
here are some pics
I have to cut out battery tray to access area for the pump pulley/ diveshaft area. some bright designer put the steering column through it . and I'm not looking to take that out too. just fab a plate to reattach.
  • Texas Deere and Horse, KennyP, Rock farmer and 1 other said thanks
