Sunstrand Rearend
7 replies to this topic
#1 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted August 04, 2013 - 01:32 PM
I am trying to pull the two halves of a sunstrand rear end apart.  I took out all the bolts and I got the two halves to split apart, but only about a 1/2 to 3/4 of an inch.  I cant get the two halves to completely separate.  I am sure there is something holding it from popping apart, but I don't know what it would be.  I have tried turning the axles to see if there was a "sweet spot" to pull it apart, but had no luck.
Anybody familiar with these to know what I need to do?
Brad.
#2 boyscout862 OFFLINE
  • 12,859 Thanks
  • 9,173 posts
Posted August 04, 2013 - 02:10 PM
Did you look in our manuals section? There are several Sundstrand service manuals that you can download. Good Luck, Rick
#3 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted August 04, 2013 - 02:37 PM
Thanks Rick,  I looked at the sunstrand manuals, and all I found was for the hydrostat pump.  I am in need of spliting the rear axle(differential) apart.  I couldn't find anything in manuals for my tractor which is an Ariens S-16H.  Any ideas where else to look? or does anyone have info on this?
Thanks
#4 olcowhand OFFLINE
  • 41,194 Thanks
  • 31,428 posts
Posted August 04, 2013 - 03:59 PM
I'm not sure, but I'd bet the differential end is a Peerless.
#5 shorty ONLINE
shorty
  • 5,485 Thanks
  • 5,263 posts
Posted August 04, 2013 - 04:13 PM
Looking across different spec sheets, it seems they used Peerless for the gear models. And Dana gt20 for the hydro models. In the repair manual for the 931 series, there is a section for rear. Not sure if that will help at all.
Edited by shorty, August 04, 2013 - 04:19 PM.
  • olcowhand said thank you
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 04, 2013 - 07:17 PM
if you have the Dana reared on a hydro 931 series tractor let me know. JD used the same rear end on the early 300 series. I should have service info for that here.
#7 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted August 04, 2013 - 07:25 PM
hey guys thanks.  I read through the service manual and I found out I have to pull the axles out to be able to pull it out.  it will be my project for tomorrow night.
Thanks again
Brad.
#8 rammer OFFLINE
rammer
  • 13 Thanks
  • 27 posts
Posted August 04, 2013 - 07:44 PM
Brad,
One of our members took the time to write the following article found in GTTalk Tech Tips.
It might help you out with the entire project.
Good luck and keep us posted on your progress - with pictures LOL.
Tom Ramsay (rammer)
Grimsby, ON
Sundstrand Series 15 Inline Pump/Motor Rebuild Apr 08, 2013 10:37 AM | Bill Petenpole in GTTalk Tech Tips / How To
hydro hydrostatic sundstrand
  • Petenpole said thank you
