Need Advice, 165 Hydro With Water In It.
9 replies to this topic
#1 arkie49 OFFLINE
arkie49
  • 2 Thanks
  • 4 posts
Posted August 03, 2013 - 10:23 PM
i mistakenly added water when topping off hydro fluid, i dont see any drain plugs,do i need to remove and drain or is there another way,also drained rear end and cant find fill plug,thanks robert
#2 MH81 OFFLINE
Posted August 03, 2013 - 10:27 PM
Robert,
:welcome: to GTTalk
It would be a big help if we knew model number of your tractor and maybe a few pics.
Good luck in the repair.
#3 DougT OFFLINE
DougT
    Dog Approved
  • 7,077 Thanks
  • 5,061 posts
Posted August 03, 2013 - 10:29 PM
robert, Welcome to the forum. I'm not up on JD hydors but the model of your tractor will help the experts around here.
#4 arkie49 OFFLINE
arkie49
  • 2 Thanks
  • 4 posts
Posted August 03, 2013 - 10:30 PM
yes,i am old and tired,hence my predicament, john deere 165 hydro ,the cooling fan mounts on side
#5 arkie49 OFFLINE
arkie49
  • 2 Thanks
  • 4 posts
Posted August 03, 2013 - 11:17 PM
well, i found the drain plug on bottom of unit,uses recessed allen screw,was covered with grime,luckily i have a forklift .i just raised up to view,cant find fill plug for rear end,but since its 90 degrees vertical i can just add some 90 and plug,that leaves  bleeding unit so i will check back later on that procedure,
#6 oldedeeres OFFLINE
oldedeeres
  • 10,300 Thanks
  • 5,025 posts
Posted August 04, 2013 - 12:27 AM
   Welcome, Robert, nice to have another J.D. man around. Take care working under the forklift, crazy things can happen when you least expect them. I will admit it's nice to be able to stand up while getting a look at things though.
#7 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted August 04, 2013 - 07:00 AM
Welcome to GTTalk Robert. You,ve done the right thing. Water in your transmission is not good!
#8 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted August 04, 2013 - 07:18 AM
Welcome to the forum, Robert! Glad you found the drain plug!
#9 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted August 04, 2013 - 08:15 AM
Welcome!  How goes the process?
#10 arkie49 OFFLINE
arkie49
  • 2 Thanks
  • 4 posts
Posted August 04, 2013 - 10:47 PM
got her running.thanks
