New To Me 140-Garden Expansion
ford 140 tiller
36 replies to this topic
#31 KennyP ONLINE
  • 40,857 Thanks
  • 47,081 posts
Posted August 13, 2013 - 07:02 PM
Good looking tractor!
  • Oppie said thank you
#32 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted August 13, 2013 - 08:25 PM
Here is an AWSOME tire I use it for tractor pulling and it is very good .Way better that the tru powers in my opinion.
http://www.greatercl...Duro-Lug/Detail
  • MH81, Alc and Oppie have said thanks
#33 Oppie OFFLINE
Oppie
  • 30 Thanks
  • 23 posts
Posted August 14, 2013 - 02:49 PM
Thank you. Im not sure those will fit though. I dont really understand what each number refers too, nor do i know whether i can put a different size tire on the rims that i have. Btw, what sets these tires apart from the tru powers?
#34 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted August 14, 2013 - 07:54 PM
traction !! The Duros don't slip as easily as the true powers ,and I  think it could be due to the angle /curve of the bars. The duro is not as steep , say 35degrees compaired to 45 degrees of the tru-powers and the price is WAY better !!
#35 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted August 19, 2013 - 09:42 PM
For a garden tractor tire for example 23 x 10.50 -12
23" = tire height
10.50 = tire width ( not the same as tread width) Tread width is usually a bit narrower depending on the tire.
12 = rim diameter.
Note that rim diameter is measured at the bead. rim widths affect tire sizes as well, a too wide a tire on a narrow rim will cause issues. as will a narrow tire on a wide rim. For my lgt 100 I want to go to a 12" wide tire.
You can usually go up or down an inch or two in tire height, and tire width, but never on rim diameter. Actually tire height is pretty much whatever you need.
all measurements are in inches
Edited by Chopperhed, August 19, 2013 - 10:01 PM.
#36 MH81 OFFLINE
  • 29,978 Thanks
Posted August 20, 2013 - 12:27 AM
Those duros do look nice. Oppie, listen to these guys... They won't steer you wrong.
Ha, sort of a pun... Steer... Tires... Oh never mind. LOL
#37 CHUCK4850 OFFLINE
CHUCK4850
  • 1 Thanks
  • 1 posts
Posted April 28, 2015 - 04:30 PM
Nice tractor. I have one just like it, and I just picked up a tiller for it. I'm missing the same 2 springs that it looks like you need as well. I would bet they are for rebound, so it doesn't bounce the tractor so much. My real problem is that I'm missing the long bar that lets the tractor lift the tiller. If I could get you to make me a drawing of yours, I can make one.
Thanks,
Chuck
  • VintageIronCollector said thank you
Also tagged with one or more of these keywords: ford 140, tiller
