Help! What Is This?
This topic has been archived. This means that you cannot reply to this topic.
7 replies to this topic
#1 Guest_gravely-power_*
  • Guests
Posted August 03, 2013 - 05:57 PM
......and do I need it?
http://tampa.craigsl...3978821676.htmlimage.jpg
#2 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 8,051 Thanks
  • 4,461 posts
Posted August 03, 2013 - 05:59 PM
That is an Ariens tractor.  Looks pretty rough.   $300 seems very high for the condition and the treatment it has likely had.
#3 olcowhand OFFLINE
  • 37,712 Thanks
  • 30,338 posts
Posted August 03, 2013 - 06:25 PM
Pretty high unless you badly needed the hydrostat out from under it to get a better tractor going.
#4 Titus ONLINE
Titus
    Bush Hog Hoarder
  • 1,791 Thanks
  • 2,303 posts
Posted August 03, 2013 - 06:39 PM
Ariens YT model I think
#5 Guest_gravely-power_*
  • Guests
Posted August 03, 2013 - 06:48 PM
Hydrostats I have. What I am running out of is good Kohlers. Is that rear lift hydraulic? Is it also used to raise and lower the deck? So the valve and piston has to be worth something. I may be able to get this for a $100.
#6 olcowhand OFFLINE
  • 37,712 Thanks
  • 30,338 posts
Posted August 03, 2013 - 07:01 PM
It's worth $100 easy just for parts.  It appears the rear lift is linked to the mid mount lift.
#7 LilysDad OFFLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 11,403 Thanks
  • 8,666 posts
Posted August 03, 2013 - 08:11 PM
What you really need are the rear wheels and you can get those for less.
#8 shorty ONLINE
shorty
  • 4,488 Thanks
  • 4,628 posts
Posted August 03, 2013 - 09:26 PM
The striping on the hood has me thinking of the GT 18 of the 931 series. The 3 point arms mount right behind the axle with a single hydraulic cylinder for rear, mid and front lift. Flip a latch and use the rear lift. Flip it back and the front and mid work together with the front having down pressure and the middle has a float
