Ariens Moving In Park
6 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted August 03, 2013 - 12:36 PM
My gt17 moves forward while its In park any ideas what would cause this
#2 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,164 posts
Posted August 03, 2013 - 12:55 PM
There are several possibilities of what it might be. The linkage might be out of adjustment. Or the cam might be worn. And the trans lock not fully engaging. If the cam is worn, the control arm off the hydro can move on its own making neutral hard to find. A bigger bushing could be put in, or you could hook a light weight spring to hold it against the cam. A local mechanic told me that some brands come with it on from factory. That is how I fixed my floppy control arm.  Adjusting the linkage is fairly easy , up by the neutralizer pedal there are adjusting nuts.
  • NUTNDUN and MH81 have said thanks
#3 JDBrian OFFLINE
  • 9,610 Thanks
  • 14,144 posts
Posted August 03, 2013 - 01:35 PM
On the JD's with the same Sundstrand hydro there is a spring that holds the cam in the neutral notch. There is an adjuster that moves the cam follower to get it positioned at neutral.  If it all isn't tight and moving freely you will get hydro creep when in neutral and/or jerky response to speed control inputs.  If you have a manual it may tell you how to adjust it but inspect the linkage for slack. As said above the hole in the cam tends to wear. I solved that on my 314 by using a larger pin in the linkage that fit tight in the worn hole.
  • NUTNDUN said thank you
#4 Wm McNett OFFLINE
Wm McNett
  • 125 Thanks
  • 169 posts
Posted August 03, 2013 - 03:43 PM
Park cable or at least thats what I call it. Mine was froze up just enough to allow it to pull the park lock pin out of the pinion drive gear but when I'd put it back in park it would not push the wire back through the cable housing, it would bend.
I had to take it off, lube it up, put one end in the vice and pull the housing, lube it, put the other end in the vice, pull the housing, lube it up, .................. repeat until it worked freely.
Page 107 & 108 of the 000127A repair manual
#5 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted August 03, 2013 - 06:55 PM
Thank you found the problem the Rubber grommet on theshift lever Is missing
#6 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,164 posts
Posted August 03, 2013 - 08:27 PM
That sounds like an easy fix. It sure can be frustrating when the tractor wont stay put.
#7 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted August 04, 2013 - 08:28 PM
Yea should be might even have one on my s14h parts tractor it really is a pain since the kids like to leave toys all over I just got into the habit of shutting it off every time I have to get off
