Haban 512 Joint Replacement Help
7 replies to this topic
#1 Littledeere OFFLINE
Littledeere
  • 1,664 Thanks
  • 1,490 posts
Posted August 03, 2013 - 11:30 AM
Ok guys need some help here worked on a bunch of stuff over the years never seen anything like these.I guess you would call these a U joint can't seem to find anything like them yet.They are a square center with 4 pins pressed in the sides with needle bearing cups on the end pressed into the yokes. I have a parts shaft here just did not want to cut it up to get them out.I just don't see any other way.If I could find new ones I would go that way.
                    Any help would be good
                                  Thanks Kenny
  • boyscout862 and JRJ have said thanks
#2 boyscout862 OFFLINE
  • 13,689 Thanks
  • 9,474 posts
Posted August 03, 2013 - 11:43 AM
I would look for a standard ujoint. Do you know how to replace a ujoint? The standard ujoint may just fit right in. If not, you may have to ream the yokes to fit. Good Luck, Rick
  • Littledeere said thank you
#3 Littledeere OFFLINE
Littledeere
  • 1,664 Thanks
  • 1,490 posts
Posted August 03, 2013 - 12:07 PM
These don't work just like a reg U joint looks like the center is made to help carey some of the load .The cups are very small only a little over 1/2 inch cross to the outside of the cup
#4 drbish OFFLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted August 03, 2013 - 01:35 PM
I looked on the haban yahoo groups site and could not find any posts pertaining to your problem.I do not know if you belong to it but here is a  link to join up.
http://groups.yahoo.com/group/Haban/
#5 diesel nut ONLINE
diesel nut
  • 773 Thanks
  • 465 posts
Posted August 03, 2013 - 01:45 PM
That looks like the joints Haban used on there snowblowers.  As far as I can tell they were made by them for there own machines.  Over the years we've tried to come up with something close at work and every time we do its either not capable of the speeds needed or the price of all the parts ads up to I think well over $200 so we never botherd to get them.  When we need to replace them we use standard 6N u-joint parts and make up a shaft.  Still not cheap but it gets them going again.       Stewart
#6 Littledeere OFFLINE
Littledeere
  • 1,664 Thanks
  • 1,490 posts
Posted August 03, 2013 - 01:55 PM
Yes I'm a member there as well but did not see anything helpful Haban had a part number for these joint but that did not get me any were as well
#7 EricFromPa ONLINE
EricFromPa
  • 4,300 Thanks
  • 3,414 posts
Posted August 03, 2013 - 04:28 PM
Could you cut up an old Bolens mower U Joint and weld it up?They have replaceable U Joints.
They should be heavy enough for a frail mower.
Here's what I'm talking about.
$(KGrHqRHJE8FD(Hf(C7)BQ8YfmcVBg~~60_57.J
#8 Littledeere OFFLINE
Littledeere
  • 1,664 Thanks
  • 1,490 posts
Posted August 03, 2013 - 05:23 PM
I'm sure I could fab up a shaft but trying to keep this as original as I can if nothing else I may cut up the shaft from a Haban sickle mower I have to fix this one I was just hopeing someboby had been into this already.
        Thanks for the ideas so far guys
