Wanted
Kohler Carburetor
9 replies to this topic
#1 Matt O OFFLINE
Matt O
  • 119 Thanks
  • 98 posts
Posted August 02, 2013 - 01:26 PM
I am in need of a Carb for a Kohler Magnum (M12- 471527). I also need the complete air cleaner assembly for the engine. these parts will be used on a wheel horse 312-8. thanks
  • OkieGt said thank you
#2 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 02, 2013 - 03:43 PM
Can you post a pic and let us see if it is different than the K-series Carbs?
  • Matt O said thank you
#3 Guest_gravely-power_*
  • Guests
Posted August 02, 2013 - 05:04 PM
They are the same.
  • Matt O and OkieGt have said thanks
#4 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 02, 2013 - 05:21 PM
Ebay has aftermarket Kohler carbs for 60.99 delivered, the air cleaner assembly may also be found there as well
#5 dodge trucker OFFLINE
dodge trucker
  • 2,297 Thanks
  • 3,013 posts
Posted September 22, 2013 - 06:02 PM
there was a member here from WI that had been advertising brand new OEM carbs for that engine for (if I remember right) $75.
#6 dodge trucker ONLINE
dodge trucker
  • 2,297 Thanks
  • 3,013 posts
Posted September 22, 2013 - 06:08 PM
whats wrong with your carb? sloppy throttle shafts can be fixed. most 12HP K  and Magnum  carbs interchange, slight differences though in the throttle shaft where the gov link connects over the years and varied applications for these ehgines
#7 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,614 posts
Posted September 22, 2013 - 07:30 PM
How about Joe's Outdoor Power?
#8 rrmeidl ONLINE
rrmeidl
  • 33 Thanks
  • 67 posts
Posted September 23, 2013 - 12:22 PM
That would be me!! Trust me the aftermarket carbs are cheap for a reason. Give me a part number and I'll see what I have.
#9 dodge trucker OFFLINE
dodge trucker
  • 2,297 Thanks
  • 3,013 posts
Posted September 23, 2013 - 07:40 PM
yup I have a newer 6HP Tecumseh whose throttle shaft is "just" starting to allow the engine to "hunt" (tec never sold throttle shaft regush kits like Kohler)  and I'm debating if it's "bad enough yet" to replace the carb, I am not interested in the aftermarket carb even for a Tecumseh... I sure would not on a Kohler.
Back in the day you could buy replacement carbs via Tillotson or Walbro or Carter instead of teh engine manufacturer  in this case though you were still gettin the exact same carb  that the engine came with, not these days
and rrmeidl I havent forgotten about you on that 8HP Kohler crank either... just have not had a chance to get around to that engine in a while
#10 rrmeidl ONLINE
rrmeidl
  • 33 Thanks
  • 67 posts
Posted September 23, 2013 - 11:47 PM
It's Rick and you said a mouthful. I looked up the carb for Matt's spec and it a 47-853-20 and I just so happen to have one. Still got a couple of cranks for the K181 too.
