Sears Ss/16 Mower Deck Adaptation Question
ss/16
8 replies to this topic
#1 Jasper OFFLINE
Jasper
  • 15 Thanks
  • 42 posts
Posted July 31, 2013 - 02:18 PM
Has anyone ever adapted a mower deck from a non-Sears Suburban and made it work on a SS/16?  I need a mower deck but can't find one to fit.
#2 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted July 31, 2013 - 06:11 PM
I would think that adaptation would be doable with a mule drive. As a matter of fact, with a three blade deck or center drive at least, it would probably be pretty easy until you get to designing the lift assembly. That might be interesting as the lift is part of the deck on those.
  • Jasper said thank you
#3 Jasper OFFLINE
Jasper
  • 15 Thanks
  • 42 posts
Posted July 31, 2013 - 08:05 PM
I have the scissor lift off one of the decks that worn out it might bolt on if the belts were not in the way.
#4 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted July 31, 2013 - 08:10 PM
If you still had the mandrels, I would suggest thinking about making one, but the sheet steel and welding might get a little $,
#5 Jasper OFFLINE
Jasper
  • 15 Thanks
  • 42 posts
Posted July 31, 2013 - 08:25 PM
I never consider making one, I do have the mandrels. I'll have to think about it I do have another one to use as a pattern.
#6 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted August 05, 2013 - 10:00 PM
How are you making out?
#7 Jasper OFFLINE
Jasper
  • 15 Thanks
  • 42 posts
Posted August 06, 2013 - 11:12 AM
Haven't had time to work on it yet I was negotiating
 with Arti for his used deck. I'm still weighing my options.
I've been focusing on get the 87' Craftsman II running that a friend gave me. The 18hp B&S is now running but I need to adjust the carb. I have to keep the choke 3/4 of the way out for it to run.
Jasper
#8 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted August 07, 2013 - 09:44 AM
Man, hard to believe you can't find a deck, I know a couple guys in my area getting ready to start scrapping some cause they got so many they don't use.
Shipping would be a killer from WI to SC.
#9 Jasper OFFLINE
Jasper
  • 15 Thanks
  • 42 posts
Posted September 26, 2013 - 08:55 PM
Sense I posted this message I have found three that I was able to purchase for $75 each.  I had to drive a ways to get them but now I have one for every tractor I own.
Edited by Jasper, September 26, 2013 - 08:55 PM.
  • MH81 and TAHOE have said thanks
Also tagged with one or more of these keywords: ss/16
