Guess What I Got Today!
111 replies to this topic
#1 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 30, 2013 - 06:11 PM
I asked the neighbor across the street if he knew of any zero-turns around. Said his SIL had one sitting in the back of his property. Went and looked at it, couldn't find any spark plugs in the engine. Anyway we struck a deal and I am now the proud owner of this:
I have gotten it to turn over, drained the old fuel. Tomorrow, I'll get new fuel. What else do I need to do to get it started. It seem the glow plugs are working and the owner said they had to be used when it was started for the first time each day. It has 5408 hours on the clock and is a Mitsubishi diesel. I think around 25 HP. Has good antifreeze in the radiator, but the water pump is a bit hard to turn. I thought the alternator was froze up, but I guess the belt was just stuck to the pullies. I will need the adjustment bracket for it, that is broken.
  • daytime dave, Texas Deere and Horse, boyscout862 and 3 others have said thanks
#2 MH81 OFFLINE
Posted July 30, 2013 - 06:17 PM
wonder why they stopped usjng it?
Looks nice Kenny, hope its an easy fix.
#3 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted July 30, 2013 - 06:19 PM
Nice find. A monster mower for sure.
#4 Fabman OFFLINE
Fabman
  • 257 Thanks
  • 374 posts
Posted July 30, 2013 - 06:29 PM
Thats one mean looking mowing machine ya got there Kenny. :thumbs:
#5 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 30, 2013 - 06:35 PM
It's a Toro Groundsmaster 322-D. He said the transaxle was out of it, but there is a spare one he had picked up. When I was draining the old fuel, I found the hydraulic filter very loose. Wonder if it's just out of fluid?
I got it mainly for the engine. Can you say FF 22-D? Gotta read some in the manual, see if I can find a wiring diagram as mice have chewed the wiring all up. It has sat for 2 years in under some trees, one tire has sidewall leaks. It will need a tube. But it's a 23-8.50x12. I think a Cub wheel would fit it for now. Has power steering!!!
  • boyscout862 and JRJ have said thanks
#6 IamSherwood OFFLINE
  • 8,390 Thanks
Posted July 30, 2013 - 06:43 PM
I have faith in you Kenny.
You'll get it going. It looks good visually. A few leaves and crap to
clean off. If you got it for the right price, I'd call it a good score.
Looking forward to seeing what you do with it.
  • KennyP and JRJ have said thanks
#7 MH81 OFFLINE
Posted July 30, 2013 - 06:44 PM
Even if the engine doesn't go in the FF, I can Say FF22 with Power Steering. :D
#8 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,456 Thanks
  • 3,364 posts
Posted July 30, 2013 - 07:01 PM
Kenny you are on a roll!!!  NIce find!
#9 UncleWillie OFFLINE
  • 15,523 Thanks
  • 8,704 posts
Posted July 30, 2013 - 07:02 PM
 I know why you moved now. You cleaned everything out at the old place.
#10 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted July 30, 2013 - 07:06 PM
Kenny, I bet since you have a wiring issue you aren't getting fuel if it has an electric shutoff solenoid.  You may also have to get the lines cleaned out if it has sat for a while.  Diesel does go bad too!
Willie has it all figured out.  :thumbs:
Ben W.
#11 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 30, 2013 - 07:13 PM
I've been trying to read the manual. I think it does have the shutoff solenoid. Got a lot of wires chewed into by mice, so have to figure that all out.
  • JRJ said thank you
#12 EricFromPa ONLINE
EricFromPa
  • 3,513 Thanks
  • 3,064 posts
Posted July 30, 2013 - 07:33 PM
Sweet find.Heck I would of left the old fuel in it if there wasn't much water in it.Throw a battery in it and crack the injector lines loose and give it a whirl.
We paid $300 for our 4 cylinder Continental gas powered GroundsMaster 72 It does not have power steering but it turns really easy any way.It had a steering column like the old Cub Cadets used but slightly longer and beefier.
Water pumps are very pricey for the Continental engines.Around $600 through Toro.
My uncle pressed the old one apart and put new roller bearings in it and found a set of seals somewhere.I forget where he got the stuff.It took him a few days to get it back together but is hasn't leaked a drop in the 6 years we've owned it.
Edited by EricFromPa, July 30, 2013 - 07:36 PM.
  • KennyP, boyscout862 and JRJ have said thanks
#13 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted July 30, 2013 - 07:53 PM
Congrats Kenny!! I wish you luck getting her running! I know you will though :D That would be awesome if you could use that engine in a FF! Good luck :thumbs:
#14 KennyP OFFLINE
  • 37,425 Thanks
  • 45,461 posts
Posted July 30, 2013 - 07:59 PM
I had about 2 gallons in it, no water!
#15 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted July 30, 2013 - 08:07 PM
Congrats Kenny!
