Cub Cadet 129 Drive Shaft Assembly
23 replies to this topic
#1 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted July 29, 2013 - 06:03 PM
Working on restoring a 129. The driveshaft coupling on the transmission end is missing the bearing. Does anyone have pictures or diagrams on how this fits together?
  • JRJ said thank you
#2 Cvans OFFLINE
  • 6,669 Thanks
  • 6,134 posts
Posted July 29, 2013 - 10:07 PM
Are you talking about the fabric disc that goes between the two coupling halves?
  • Jkrogers said thank you
#3 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted July 30, 2013 - 08:07 AM
Thanks Chris, I am working on that end but that is not the problem. Where the drive shaft slips into the coupling there is a spot for a ball bearing to fit on the coupling. I have run across a reference for this in manual somewhere but I can't find it. I am not sure what the original purpose for this ball bearing was or if the coupling has been upgraded over the years and no longer requires this. I can post pictures if needed.
#4 Cvans OFFLINE
  • 6,669 Thanks
  • 6,134 posts
Posted July 30, 2013 - 11:58 AM
I have two 129's and I for the life of me can't remember the part your talking about. At my age that is normal though.  :smilewink:
If I get time later today I will try and get a photo for you.
#5 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted July 30, 2013 - 03:35 PM
There should not be a bearing unless you pulled the Charge pump.
Here's a good manual.Covers Models 86-1650   It's 32Mb just click and (Save link as) .Pdf Document and wait for it to download.
http://www.oldengine... 1450, 1650.pdf
Edited by EricFromPa, July 30, 2013 - 03:38 PM.
  • Cvans and Jkrogers have said thanks
#6 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted July 30, 2013 - 04:28 PM
I seem to remember something about a round steel ball in there somewhere.
Mine doesn't have one.
#7 Cvans OFFLINE
  • 6,669 Thanks
  • 6,134 posts
Posted July 30, 2013 - 06:47 PM
Thanks for the post. That photo looks like the way I remember mine being put together.
#8 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted July 30, 2013 - 07:00 PM
That is the first time I had heard of a ball being used as a spacer for the drive shaft. It is written in the manual, but does not list a part
number. I know mine does not have one. Whether it did from the factory, I don't know.
Geno
#9 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted July 30, 2013 - 07:07 PM
There is a ball bearing for the Internal Wet brakes on a narrow frame Cub Cadet but a 129 should have Dual Disk brakes unless some one swapped out the rear.THAT is highly possible.
Do you have any pics of the tractor and Transaxle in question?
Here's a pic of where the Ball goes on a Standard Transaxle with Wet Brakes.
Edited by EricFromPa, July 30, 2013 - 07:19 PM.
#10 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted July 30, 2013 - 09:02 PM
Yes that is it! It looks like it would be used as a spacer. Is it covered in the manual above? Has there been an upgrade and this spacer not needed in the upgrade? I really appreciate the replies!
  • EricFromPa said thank you
#11 EricFromPa ONLINE
EricFromPa
  • 3,672 Thanks
  • 3,118 posts
Posted July 31, 2013 - 01:31 AM
Yep it's in the manual I posted.
:wewantpics: :camera: :wewantpics:  :bigrofl:
#12 Jkrogers OFFLINE
Jkrogers
  • 9 Thanks
  • 70 posts
Posted August 01, 2013 - 10:25 AM
Here are pictures of the transmission coupling on the 129. You can see the place where I think the steel ball would fit.  In the other picture is the coupling with the steel ball placed in like I think it would fit.  The steel ball that is in the picture is from an old bearing out of the steering column.
If I am correct, does anyone know what size steel ball is required? If this part has been updated and the steel ball is not required as a spacer, I would rather just get the updated part and mess with the bearing.
As always guys, I am very much appreciate all the help.  I continue to be amazed at how well made these machines are made.
  • Cvans said thank you
#13 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted August 01, 2013 - 12:00 PM
There should not be a bearing in there.  That spot where you have the ball is just worn. Ordinarily, it would be just be a round hole.
This is what it should look like.http://www.ebay.com/...=item43bda0d123
Edited by LTD, August 01, 2013 - 12:02 PM.
#14 Cvans OFFLINE
  • 6,669 Thanks
  • 6,134 posts
Posted August 01, 2013 - 12:12 PM
Those photos help a lot. I could not for the life of me remember a ball in the coupling. I can see from the photos where one could think that though.
#15 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,234 posts
Posted August 03, 2013 - 07:27 PM
$55 dollars? holly crap batman! Looks like a cast flange with three holes in it! Does also fit John Deere?
Joe
