I have a B-110 and im trying to find a part. the part im looking for is the front drive coupling. its the round disc with 4 holes and a spacer in each hole and had a part of rubber between the metal parts. it bolts on to the engine then to the front drive shaft. does anyone know where I can get one of these and the four spacers or maybe know the parts number for these parts. Mine has gotten ovald out and the spacers are about cut threw. any help would be great. thanks
Need A Little Help
#1
OFFLINE
Posted July 29, 2013 - 09:47 AM
- boyscout862 and JRJ have said thanks
#2
ONLINE
Posted July 29, 2013 - 11:07 AM
Try this manual for the part numbers. The B110 and B112 should be the same. http://gardentractor...ers-parts-list/
Then contact a site sponsor or your local Simplicity dealer. In a pinch, I have fabricated similar connectors from the inner wheel liner of a truck tire. Good Luck, Rick
Edited by boyscout862, July 29, 2013 - 11:08 AM.
#3
OFFLINE
Posted July 29, 2013 - 11:30 AM
First try our site sponsors, but if they don't have the part, contact Brenda at Sandy Lake Implement ([email protected])
Brenda can get it for you.
- boyscout862 said thank you
#4
OFFLINE
Posted July 29, 2013 - 11:48 AM
thank you all very much
#5
OFFLINE
Posted July 29, 2013 - 08:38 PM
The new one will be a fiber disc and you will need the washers, they are a special washer and 2 are needed per hole. These are still available from Simplicity as far as I know. Hope this helps! Bill.
