Exploding Kohler Balance Gears-With Pics And Story
28 replies to this topic
#16 TimW OFFLINE
TimW
  • 420 Thanks
  • 274 posts
Posted July 31, 2013 - 08:23 PM
For just a little more info.  I bought this tractor as is about 3 weeks ago out of South Central Indiana.  The guy had apparently had it blow up a week or so before I bought it.  He was not a PK collector, just a guy who mowed with it and said he had owned it since 1982.  I think it is a '77 model.  He had a video of it running on his cell phone with the damage.  He responded to a want ad I had posted for PK parts and transmissions and made me a good deal on the whole tractor.  It has the dual transmissions.  He had no idea what caused the damage, I deduced it from the missing balance gear and the other things I saw.  I pulled the head and it had a standard piston and good bore, so from what he said and what I saw, I am fairly certain it had never been taken down or rebuilt.
#17 js5020 OFFLINE
js5020
  • 716 Thanks
  • 809 posts
Posted July 31, 2013 - 08:55 PM
Hmmm the 16 Auto has these still intact, guess I better take them out.  The Gravely walkbehind with the K301 never had them, so I guess not all K series Kohler came with them.
#18 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,311 Thanks
  • 10,287 posts
Posted August 01, 2013 - 07:02 AM
I have a k341 from a genset. It didn't have them.
Does anyone know what makes them come apart? They're a pretty good chunk of iron. Is it the keeper that holds them on???
#19 olcowhand ONLINE
  • 43,147 Thanks
  • 32,005 posts
Posted August 01, 2013 - 08:43 AM
I have seen the keeper clips come off, bearings go bad causing teeth to not mesh proper, and in a few cases, the pins come loose in the block.
  • LilysDad said thank you
#20 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted August 01, 2013 - 09:27 AM
Makes me glad that I listened to the advice given by many here on the site to remove them from my K341 when I had it apart to fix the governor.
#21 js5020 OFFLINE
js5020
  • 716 Thanks
  • 809 posts
Posted August 06, 2013 - 07:37 PM
I put the K341 together today,,,, the balance gears didnt go back in the engine, didn't evem check to see if the bearing were good or bad.
#22 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,540 posts
Posted August 09, 2013 - 10:14 AM
I asked this back earlier in the thread but don't believe anyone answered... For those of just that don't know, how can you tell if the balance gear is in there without taking the enging apart? Are there certain spec' numbers that that do and don't? certain OEM's that had them and didn't? I'm up to 5 K engines now ranging from 1972 Wheel Horse to a 1996 replacement engine... and have no idea if any of them have this gear.
#23 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted August 09, 2013 - 11:07 AM
The cool thing is that it still ran. Nothing like a K series Kohler!!!
#24 Guest_gravely-power_*
  • Guests
Posted August 09, 2013 - 12:20 PM
There is no way to tell if an engine has them with out removing the oil pan.. Some applications had them, other applications didn't.
#25 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted August 09, 2013 - 12:33 PM
I don't know if there would be enough room to see by taking the cam cover off and shining a light in. Kind of has me curious now to see if you can tell that way.
#26 Ryan313 OFFLINE
  • 3,408 Thanks
  • 5,242 posts
Posted August 09, 2013 - 12:41 PM
If you look at the crank side of the engine, you will be able to see the holes for the pins that the gears are on. I went and took a picture of a k321 I have apart right now. I also drew two arrows on the block, pointing to the holes for the balance gears. If it has these holes, then it has (or had at one time) the balance gears. If the holes are not there, then it never had the balance gears.
037D93F5-D0D4-45D5-B189-B657EF527CCC-298
This is only from my own detective work, and is not official in any way.
  • Sawdust said thank you
#27 milkdud OFFLINE
milkdud
  • 67 Thanks
  • 68 posts
Posted September 02, 2013 - 09:45 PM
What is involved with taking them out?  I know my K321 has them.  I saw them when I was working on my ford LGT145.
thanks
#28 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,512 Thanks
  • 6,163 posts
Posted September 02, 2013 - 10:29 PM
thanks
You have to pull the crankcase cover off and remove those pesky buggers before they bite you..  It is possible now to have the crankshaft ground to balance the engine and make it run smoooooth!  PM me for info..
  • milkdud said thank you
#29 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,512 Thanks
  • 6,163 posts
Posted November 22, 2013 - 04:27 AM
http://www.ihcubcade...ler part ii.pdf
