Ac416 Axle Pin Bushings
6 replies to this topic
#1 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 28, 2013 - 06:12 PM
Has anyone installed a set of these? I bought some new ones and sure would like some advice on how to install them, the old ones fell out. It doesn't seem like there is anything that holds them in other than pressure, is that enough??? Thanks guys.
#2 sammiefish OFFLINE
sammiefish
  • 8 Thanks
  • 26 posts
Posted July 31, 2013 - 06:12 PM
if you are referring to the bushing pressed into the front axle... then, yes, it is a press fit... I've done 2 of my front axles so far... and will continue as time goes on.
have you tried to get the old ones out???
I would not recommend a screwdriver and hammer... tried it... not much luck there.
I used an impact gun with a long rod...
push each one out from the opposite side... I needed a hydraulic press to get the new ones in there...
no chance at all of them falling out... really!!
Edited by sammiefish, July 31, 2013 - 06:16 PM.
  • OkieGt said thank you
#3 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 31, 2013 - 07:44 PM
There werent ANY bushing left in there. I bought newones and used a bearing driver with red locktitem they are in there, the thrust washers and bearings are installed, all new tires and rims painted and I'm driving it
  • olcowhand said thank you
#4 olcowhand ONLINE
  • 38,783 Thanks
  • 30,694 posts
Posted July 31, 2013 - 08:18 PM
I was gonna say you could use a bolt & very thick washers on a bolt with nut & "pull" them into place, but see you have them in now.  I drilled through after installing the ones I made, tapped out, then installed a grease zerk.  The grease fitting also reached into the bushings to further hold them in place.
#5 OldAllis52 OFFLINE
OldAllis52
  • 272 Thanks
  • 160 posts
Posted August 01, 2013 - 03:22 PM
Where did you find the bushings and do you remember the part number?
#6 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted August 01, 2013 - 06:25 PM
Jacks small engines 44.00 shipped, I'll look at my invoice for the part number but I think you can look it up on their parts look up, I think OCH posted the part number on a early thread last week
  • OldAllis52 said thank you
#7 olcowhand ONLINE
  • 38,783 Thanks
  • 30,694 posts
Posted August 01, 2013 - 06:35 PM
You can find my post with the info HERE.
  • OkieGt and OldAllis52 have said thanks
