Weedeaters
5 replies to this topic
#1 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted July 28, 2013 - 12:07 PM
Anyone know why a royobi weedeater runs on choke but when I try to take it off of choke it wants to die..
    I put a new carb-kit in it .. Same thing...
   Think it could be the needle not adjusted  right ??
   Any thoughts ???        Thanks   sodi
#2 HDWildBill OFFLINE
  • 8,985 Thanks
Posted July 28, 2013 - 03:16 PM
Is this a 2 stroke or 4?  Check your fuel lines from the carb all the way into the tank. I'll bet ya the feed line is cracked. Also make sure the tank is vented.
  • CRFarnsworth said thank you
#3 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,520 Thanks
  • 6,166 posts
Posted July 28, 2013 - 03:18 PM
A common problem is cracks in the fuel pick-up line inside the tank..  The thing picks up air and all bets are off!!
#4 Lmiller3358 OFFLINE
Lmiller3358
  • 1,568 Thanks
  • 1,469 posts
Posted July 28, 2013 - 07:56 PM
Yep, sounds like it's sucking air somewhere
#5 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted July 29, 2013 - 12:59 PM
Thanks all will try it...   sodi
#6 wku88 OFFLINE
wku88
  • 23 Thanks
  • 40 posts
Posted July 29, 2013 - 07:53 PM
Check and make sure the cylinder screws are tight.They have a habit of vibrating loose.
