Shifter Problem With Cub 100
1 reply to this topic
#1 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted July 27, 2013 - 08:29 PM
The 100's shifter moves but the trans stays in gear.  I'm assuming that the shifter plate has to come off and see if the ball on the bottom came off ?   I've done that with Wheel Horses not sure with a cub
Any thoughts ?
#2 IHCubGuy OFFLINE
IHCubGuy
  • 1,590 Thanks
  • 1,629 posts
Posted July 27, 2013 - 11:21 PM
The ball on the end of the shifter is part of it.  Likely not broken off.  I would pull the 8 bolts out of the cover and see if the cup that is welded to the shift handle is broken off.  This is a common problem on the gear drive cubs.  Either way pulling the cover should reveal the problem though.
