Briggs Model 8 Round Top
4 replies to this topic
#1 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted July 27, 2013 - 03:37 PM
I am having some problems with my DB. It will start and run, but is down on power and dies if I put much load on it. I have cleaned the carb, and checked the plug, they are both good.
It acts like it is running out of gas, but its going enough gas.
Could it be the points?
  • JRJ said thank you
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted July 27, 2013 - 04:57 PM
On those it could be the points or the condenser, most of the time it is. Bad compression also, but I would check to see if you have a nice blue spark first.
#3 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted July 27, 2013 - 07:42 PM
Does anybody have a new set of point and condenser they would be willing to sell??
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted July 28, 2013 - 06:43 AM
The points are 29667.  I am temporarily out of stock.  However, I would take a points file and clean up your old ones a bit and they should be good to go.  In all my Briggs repair work (and I've done quite a few) I've only put new points on one engine.
The condenser is a 29861.  I have a bunch of those.
Ben W.
  • Amigatec said thank you
#5 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted July 28, 2013 - 06:49 AM
How much for the condenser?
