K Motor W/out Fuel Pump?
12 replies to this topic
#1 glgrumpy OFFLINE
  • 8,609 Thanks
  • 7,920 posts
Posted July 27, 2013 - 01:00 AM
Have 14 hp K motor for my PK. Was going to use another I had picked up instead, but found it was not as good as shape on some things as first thought. SO, now have orig engine all apart and gonna rebuild it. Can't decide if I wanna pull the balance gears out for good, always many opinions on those. Think they will stay out.  Most of these old engines I have need a fuel pump because they are missing those when purchased. I'm hearing No kits available for metal pumps now anyway and plastic ones not so good plus lots of $$ to buy. PK's have gas tank above the engine and I'm thinking I should be able to run a gas line correctly to the carb that won't need a pump. What think? Anyone ever try this?  I have a small Wheelhourse B-80 that I did that too and it runs fine, no issues. It is a K 8hp engine. I have Briggs engines in my MTD's that also are gravity feed and no problems.
  • larryd said thank you
#2 nbent OFFLINE
nbent
    customizer
  • 673 Thanks
  • 538 posts
Posted July 27, 2013 - 01:09 AM
as long as the back tires are aired up you shouldnt have a problem i have an international farmall h that is gravity feed into the carb and as long as the tires are full of air it runs fine
#3 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted July 27, 2013 - 01:13 AM
Only one way to find out for sure :D
I have been tempted to test one out, but just haven't yet.(some day lol)
Also Just recently someone found this company in MA that remakes kits for the Kohler (metal) pumps here is the link http://maritimedragr..._automotive.htm
Scroll down to the green section and click on Fuel Pumps, then next page has a button Kohler fuel pump kits
#4 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 27, 2013 - 05:31 AM
Run an electric pump
larryd
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 27, 2013 - 06:13 AM
Unless there is something special in the float and needle that requires pressure for it to fill it should work on gravity feed.
#6 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted July 27, 2013 - 07:02 AM
OK, I am officially confused about this fuel pump issue. My Cub has a K301 and it is just gravity fed and has no problems. So, some of the K
engines need pressurized fuel to get past the needle and seat?
Geno
#7 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted July 27, 2013 - 07:17 AM
I'm with Larry: if Chris' great Kohler fuel pump resource can't help you, you could always put on an electric fuel pump.  Otherwise, you can probably convince it to work on gravity feed.
Geno
Geno, I don't think that the Kohlers need pressure to get past the needle.  The carburetors are nothing more than a Walbro or a Carter/Kohler, and used everywhere else without fuel pumps.  Somebody correct me if I'm wrong, though, because I know Kohler did modify their parts.
Ben W.
#8 esbbent ONLINE
esbbent
  • 403 Thanks
  • 239 posts
Posted July 27, 2013 - 08:24 AM
I have  a MF16 with a K341 fuel pump on it quit. The fuel tank sits higher than the engine. I just took fuel pump off put a plate over the hole ran fuel line right to the carb and it runs just fine.
#9 Cubcadet125 OFFLINE
Cubcadet125
  • 5 Thanks
  • 3 posts
Posted July 28, 2013 - 01:42 AM
My 1971 pk runs great with the fuel pump unhooked and plumbed gravity fed fuel no problem
#10 twostep OFFLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted July 29, 2013 - 01:15 PM
My understanding is that they only need a fuel pump if the fuel has to be lifted or pulled from the back of the tractor. If the tank is pretty close and higher than the carb then no need to run a pump. Something else that helps even with a pump is to alwasy keep the tank topped off.
#11 glgrumpy OFFLINE
  • 8,609 Thanks
  • 7,920 posts
Posted August 04, 2013 - 11:17 AM
Update: Ordered that cover plate, is actual Kohler part and came quick by UPS of all things!  No gasket in it, would think they could have thrown that in. Be awhile before this goes together, but seems all in order.
#12 gopher OFFLINE
gopher
  • 763 Thanks
  • 757 posts
Posted August 04, 2013 - 09:00 PM
That is one way to check if pump is bad on K's tank above motor. I know of no float carb needing pressure . In fact The only thing comes to mind is injector motor.
#13 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted August 04, 2013 - 09:21 PM
I more or less did the same thing with my MF16, runs fine.
Edited by DH1, August 04, 2013 - 09:21 PM.
