Bad News . My Jd314 Died
k321
19 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 27, 2013 - 12:21 AM
Ok the story goes like this. I made my usual trip on my JD314 K321 to the coffee shop yesterday pulling my cart taking a borrowed welder back to my neighbour on my way. I left his shop got to coffee shop. Shot the bull for a couple hours got on my tractor it started just fine idled for about a minute while I talked to a friend. It died and hasn't hit a lick since. I have spark, fuel pump works good, fuel in carb bowl. Has compression. So I reinstalled the plug. Still no start. Removed plug again and I noticed the plug was dry and it should have been wet as much as chocked it.
Any help would be appreciated.
I'm going to bed, goodnight to all
Thanks
larryd
Edited by larryd, July 27, 2013 - 12:28 AM.
  • KennyP, boyscout862, jd.rasentrac and 2 others have said thanks
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted July 27, 2013 - 12:31 AM
Larry It sounds to me like something is just blocked in your carb. Do you have a fuel filter on this?
From all you have said, I don't think you have anything seriously wrong.You could always try shooting some carb cleaner in the throat of the carb 1st to see if she fires off.
I just think since it was running fine, there were no strange noises, you have spark and you know you have fuel to the carb, then that points in the direction of just a stuck needle vale or one of the small ports in the carb has a piece of junk plugging it.
Good Luck!
  • boyscout862 and larryd have said thanks
#3 glgrumpy ONLINE
  • 8,816 Thanks
  • 8,014 posts
Posted July 27, 2013 - 01:06 AM
Died?  That will need a BIG BIG hole to bury it!  That's what I do with all our pets when they pass on! Happy Digging. A few beers will be helpful and final words when done! :rolling:  :beer:
  • WNYTractorTinkerer and larryd have said thanks
#4 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,281 Thanks
  • 6,083 posts
Posted July 27, 2013 - 02:15 AM
How much compression??  Did you use a tester??  May be a cam or intake valve issue..
  • jd.rasentrac and larryd have said thanks
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,812 Thanks
  • 4,305 posts
Posted July 27, 2013 - 03:58 AM
Hi Larry,
if the engine has compression, the spark works and is try (or wet), it must be the carb. And a fuel filter is always helpful.
EDIT: always remember, nothing runs like a Deere ildeere.gif
Edited by jd.rasentrac, July 27, 2013 - 04:00 AM.
  • larryd said thank you
#6 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 27, 2013 - 05:03 AM
Ok I didn't test comp with tester but it will blow finger off plug hole. It has an inline filter and lots of gas comes out of line at carb inlet when turning over. Bowl was full of gas so needle wouldn't be stuck. I don't think it is valve or cam because it was running fine and just shut off no noise's. I did spray cleaner in throat a few minutes ago and it didn't even attempt to fire . That doesn't sound good.
larryd
#7 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,812 Thanks
  • 4,305 posts
Posted July 27, 2013 - 05:45 AM
Then maybe the spark plug doesn't work right. Sparking alone isn't enough, the heat is important (hard for me to explain) and testing the compression with the thumb is not the right way :smilewink:    It's a pity that you live so far away... :wave:
  • larryd and JRJ have said thanks
#8 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 27, 2013 - 06:09 AM
Larry, do you have a nice snappy blue spark? If the plug is dry it sounds like you aren't getting any gas. If you put your hand over the carb inlet does it produce a vacuum when cranking. The valve action can be viewed by taking off the small cover where the PCV breather tube exits.
#9 KennyP ONLINE
  • 41,010 Thanks
  • 47,164 posts
Posted July 27, 2013 - 06:21 AM
I hope it's something simple, Larry!
#10 boyscout862 ONLINE
  • 13,560 Thanks
  • 9,434 posts
Posted July 27, 2013 - 06:24 AM
I would suspect that you got a little water in the gas. If a small bubble of water forms in the fuel bowl of the carb it can temporarily kill the engine. Try a little gas directly down the carb and see if it runs. Sometimes this will also suck the water through and solve the problem. That is why sometimes a GT will die, you leave it for a day, the water evaporates out, and then it runs fine. Good Luck, Rick
#11 MH81 OFFLINE
  • 29,979 Thanks
Posted July 27, 2013 - 06:58 AM
My votes are contaminated fuel (dirt, water, etc) mucking up the carb or the spark plug says "Champion" on it.
#12 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted July 27, 2013 - 07:25 AM
You need to check your points and/or condenser.  Just because you have a spark doesn't mean it is hot enough to fire in compression.  Take a points file and clean up the contacts.
Is your governor spring right?  Did it break?
Ben W.
#13 mean and green OFFLINE
mean and green
  • 3 Thanks
  • 2 posts
Posted July 27, 2013 - 08:20 AM
Hi Larry. If you have fuel in the bowl but none making to the engine , first I would put a little fuel directly into the carb and see if it fires. If the engine fires, I would check your main jet in the carb where it picks the fuel up to make sure nothing is blocking it. Some pickup tubes have two Inlet holes at the bottom , others have the two inlet holes in the bowl retaining screw wich all need to be clear. Hope this helps
#14 boyscout862 ONLINE
  • 13,560 Thanks
  • 9,434 posts
Posted July 27, 2013 - 10:00 AM
Hi Larry. If you have fuel in the bowl but none making to the engine , first I would put a little fuel directly into the carb and see if it fires. If the engine fires, I would check your main jet in the carb where it picks the fuel up to make sure nothing is blocking it. Some pickup tubes have two Inlet wholes at the bottom , others have the two inlet wholes in the bowl retaining screw wich all need to be clear. Hope this helps
Welcome to GTT. I hope that you enjoy our group. Good Luck, Rick
  • larryd and mean and green have said thanks
#15 DougT ONLINE
DougT
    Dog Approved
  • 7,123 Thanks
  • 5,084 posts
I'm with Allen on this one, Try a different plug. I lost one in the middle of the parade last weekend at Plain City. Got pulled back to the show, swapped plugs and it fired up on the first spin.  :wallbanging:
Also tagged with one or more of these keywords: k321
