Help Needed With 1963 Mm
6 replies to this topic
#1 tractor_guy OFFLINE
tractor_guy
  • 4 Thanks
  • 2 posts
Posted July 26, 2013 - 09:07 PM
I have a 1963 MM GT.  I think it is a model 100.  I am having problems with the clutch linkage.  There is a tab "thing" on the clutch shaft that rides near the drive pulley on the trans.  It appears as if it is supposed to engage the pulley at some point, but it has come loose, and the clutch is not working properly.  If someone can post a link to a manual for this thing or post a picture of where it is supposed to be and how it is supposed to work that would be great.
Thanks
Joe
  • A.C.T. and larryd have said thanks
#2 KennyP ONLINE
  • 40,889 Thanks
  • 47,094 posts
Posted July 26, 2013 - 09:38 PM
Welcome to the forum! I hope this will help you:
Attached File  Jacobsen Chief Tractors Parts list.pdf   2.75MB   145 downloads
If it does, I'll see if I can match an operators manual to it. Page 17 has the clutch and brake parts.
  • chris m and larryd have said thanks
#3 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted July 26, 2013 - 09:39 PM
I don't have a picture atm but I'll try an explain it for now.
On those trans the stopping brake ( on right side) does NOT stop the input shaft (left side) from spinning when it is applied.
So what they did was put an adjustable piece with a small brake pad type material on the rod for the Clutch/Brake pedal.
When you step on the Clutch/Brake pedal (all the way) that brake material should move forward and contact the inner edge (at the front) of the input pulley. This stops the input from spinning. It is very important to be sure the input pulley is stopped before shifting one of these 3 speed trans!! One it will destroy it and two parts are near impossible to find for these trans.
Mine was missing the brake material so I just cut a piece of material in a wedge shape, drilled and counter sunk 2 small holes and riveted the piece to the little metal bar.
Good luck! And if you need more info or help let me know.
  • larryd said thank you
#4 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
It had a little piece of brake pad adhesive on the metal and when you step on the brake /clutch. It will rub on the pulley and help it stop faster.
#5 tractor_guy OFFLINE
tractor_guy
  • 4 Thanks
  • 2 posts
Posted July 26, 2013 - 10:32 PM
Thanks guys.  between the manual and the description I think I can get it back right.  Just need a little friction material.
Joe
#6 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 26, 2013 - 11:00 PM
Welcome Joe . Most of the time there is usually answers to your questions and problems. Great place to learn new things and information on most anything from our GT's to cooking
larryd
  • chris m and A.C.T. have said thanks
#7 glgrumpy OFFLINE
  • 8,809 Thanks
  • 8,014 posts
Posted July 27, 2013 - 12:45 AM
Hey Joe, glad you could make it here.  I KNEW there would be some Jac guys to help you out. Seeya around!
