Wonder if it's really 250lbs, seems like they would have had to use 3/8" plate steel to be that heavy. I think that's what Kenny is trying to say. If the box is 250, you could add another 200-400 lbs, That would be over 450-650lbs, way more weight than any GT needs
As for the 'empty' weight, 250 lbs seems to be just about right.
1/4" sheet weighs 10#/SqFt. The 5 solid sides at 4 SqFt each give you 20 SqFt. That would be 200# if it's 1/4" sheet. Then you need to add in the weight of the tube and other bits and pieces.
The CAT 0 spec calls for a max of 20" inside to inside for the lift arms. If the mounting tabs are also 1/4" that gives you 23 1/2" inside to inside on the tabs. and with the pins attached to them pointing in, that should just barely make the CAT 0 spec.
At that point, you would have to measure your particular tractor's 3-pt, as not all of the GT's met the full CAT 0 spec. Sears in particular, used a "Limited CAT 0" that used the CAT 0 pins, but was narrower than a true CAT 0.
John Deere is doing the same thing with their current GTs like the X700. They call it a Limited CAT 1, but it's actually CAT 0 spacing using CAT 1 pins.
Related Threads
Garden Tractor Forums
951.2K posts
49.2K members
Since 2010
