Marvel Schebler Carb
13 replies to this topic
#1 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,299 Thanks
  • 9,779 posts
Posted July 26, 2013 - 06:11 PM
I have this carb on a Wisconsin ABN. I need the main needle and throttle shaft packing. Is it still possible to purchase these?
  • hamman and larryd have said thanks
#2 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,436 Thanks
  • 2,860 posts
Posted July 26, 2013 - 06:23 PM
Is this about the same carb as on a Allis Chalmes WC? If so, I believe you can still get them at Stiner Tractor Parts. Roger.
  • LilysDad said thank you
#3 IamSherwood OFFLINE
  • 8,391 Thanks
Posted July 26, 2013 - 06:39 PM
I'm about to start working on an ABN too.
Mine has a Marvel sch......   VH14. If that helps any.
I did a google search, and there a few places that list
parts available.
  • hamman and LilysDad have said thanks
#4 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted July 26, 2013 - 06:42 PM
Yes you can buy some new parts for these.
These are the same carbs used on the Bolens Ridemaster and I been lucky to pick up 2 NOS.
There was a VH12 and VH14.
  • DougT, hamman, IamSherwood and 2 others have said thanks
#5 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,299 Thanks
  • 9,779 posts
Posted July 26, 2013 - 07:07 PM
Mine is a VH14.
  • IamSherwood said thank you
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted July 27, 2013 - 07:08 AM
If you are needing the part, it would need to be NOS.  I could track one down for you if you need it, since out of all the guys I deal with for parts at least one will have the pieces.
You lucky dog...  how do you find all the good deals?
Ben W.
#7 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,299 Thanks
  • 9,779 posts
Posted July 27, 2013 - 10:28 AM
Ben W.
If you can put your finger right on it, I would appreciate it. You know the reputation of the folks you order from.
  • superaben said thank you
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted July 28, 2013 - 07:04 AM
I'll let you know what I find.
Ben W.
#9 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,299 Thanks
  • 9,779 posts
Posted August 23, 2013 - 05:50 PM
I got the rebuild kit for this Marvel Schebler model VH14 carb. This carb is from a Wisc. ABN engine. The engine always started poorly and I think the carb is a little iffy.
The main reason I got the kit was because the packing was bad on the main needle. Along with that I felt that the throttle shaft was a little loose. When I looked up a parts diagram they showed a schematic for a VH92 which superseded it. The 92 shows there are dust cap/packing on each end of the throttle shaft. When I opened up my VH14, it doesn't have that. It has rolled thin brass shims on each end and they don't fit too good, pretty loose. I have to think the carb would run better with less clearance at the shaft bore.
So . . . I'm wondering if I should countersink the bores for the rubber dust caps, or if I should try to make some new brass tubes that fit better.
Edited by LilysDad, August 23, 2013 - 05:51 PM.
#10 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,299 Thanks
  • 9,779 posts
Posted August 24, 2013 - 08:14 AM
>bump<
#11 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted August 24, 2013 - 10:04 AM
Can you post pics of these areas in question?
#12 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,299 Thanks
  • 9,779 posts
Posted August 24, 2013 - 01:44 PM
I couldn't wait so I decided to make new brass bushings. The original bushings were made out of .002 brass shim. I turned new ones out of brass and made them .020 thick. They're just thin enough to allow the shaft to turn unimpeded.
#13 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted August 24, 2013 - 01:48 PM
Sounds like a solid repair to me.  I've done this before on carbs & always worked fine.
#14 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted February 06, 2014 - 10:14 PM
Do you happen to remember the part number for the kit?  I am having a heck of a time figuring out which kit to order for my VH14 off an ABN.  Did it come with a replacement throttle shaft?
Edited by New.Canadian.DB.Owner, February 06, 2014 - 10:15 PM.
