* * * * * 3 votes
2Nd Annual Ball Hollow/gtt Plow Day
411 replies to this topic
#121 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted September 09, 2013 - 09:41 AM
I'm trying to get my trailer repaired, got some decent repair to do on bed and dog decided last week I needed to rewire it all :wallbanging:
Haven't even looked at tractor, it's still in mowing mode. Have to remove that and re-fill a rear wheel weight as old concrete fell out.
Hopefully I will be ready!
  • olcowhand, Texas Deere and Horse, Craig. and 1 other said thanks
#122 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted September 11, 2013 - 06:59 PM
Got about 10 acres bush hogged, and cut around the pond & around field next to Dad's house to start sprucing up for plow day.  Will do more tomorrow & finish over the weekend.  I've got a lot to get done, but it'll all get done!  :thumbs:   I gotta get that porta pot here in time, or I'll have to set buckets behind the barn for ya's!   :rolling:
  • Texas Deere and Horse, Craig., KennyP and 1 other said thanks
#123 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted September 11, 2013 - 07:08 PM
Don't worry about the buckets as long as someone has a post hole digger, we are good lol!
Eric
Sent from my SPH-D700 using Tapatalk 2
  • olcowhand, Texas Deere and Horse and Craig. have said thanks
#124 KennyP ONLINE
  • 52637 Thanks
  • 53133 posts
Posted September 11, 2013 - 07:33 PM
Eric
The buckets give you something to sit on! Just have to cut the bottoms out though!
  • Texas Deere and Horse and Craig. have said thanks
#125 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted September 11, 2013 - 07:47 PM
Not gonna have a hole under the buckets.  Gonna draw names who takes filled buckets home with you to dispose of the contents.  I have lids for "most" of the buckets!   :bigrofl:
#126 twostep OFFLINE
twostep
    Rockstar
  • 1994 Thanks
  • 2541 posts
Posted September 11, 2013 - 09:03 PM
Finally got the rear tires on the kubota filled tonight. I squeezed 3 gallons of RV antifreeze and 2.5 gallons of water in to each... on top of the 4 gallons(i think) that was already in each. I don't really see how I fit over 9 gallons of fluid in those tires. All I KNOW is that they are heavy!!! Should help pull that plow a little better.
Daniel, Did you all get any rain earlier? Our ground is getting pretty hard right about now.
#127 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted September 11, 2013 - 09:07 PM
Bobby, If the ground gets too hard, we'll jerk the bottoms off the plows and chisel  plow his corn fields !! :thumbs: :rolling:
  • KennyP and twostep have said thanks
#128 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted September 11, 2013 - 09:09 PM
My two cents is, don't over inflate the tire.  Enough pressure to hold the bead, low enough the tire will deform and flatten to hug the ground.
#129 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted September 11, 2013 - 09:34 PM
Ground is dry, and not a drop of rain here today.  Might make for some hard plowing if no rain comes before plow day.
#130 twostep OFFLINE
twostep
    Rockstar
  • 1994 Thanks
  • 2541 posts
Posted September 11, 2013 - 09:51 PM
Daniel, the plowing wasn't easy last year... It was pretty wet!
#131 KennyP ONLINE
  • 52637 Thanks
  • 53133 posts
Posted September 12, 2013 - 04:49 AM
I have 6 lbs. in the FF tires.
I'm ready no matter the conditions!
  • HowardsMF155 said thank you
#132 KennyP ONLINE
  • 52637 Thanks
  • 53133 posts
Posted September 12, 2013 - 05:41 AM
I have extra lids! I'm prepared!
  • dropped82 said thank you
#133 daDoug OFFLINE
daDoug
  • 16 Thanks
  • 18 posts
Posted September 12, 2013 - 06:56 AM
I drink lots of fluids, but rarely overeat just before and on a PD.
"What goes in must come out".
#134 twostep OFFLINE
twostep
    Rockstar
  • 1994 Thanks
  • 2541 posts
Posted September 12, 2013 - 07:47 AM
Yup, same here... the lower pressure makes for a smoother ride too!
#135 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted September 12, 2013 - 10:55 AM
CORRECTED ADDRESS FOR PLOW DAY IS:
356 Ball Hollow Rd. 42748
This is my Dad's place 2 miles up the road. When you come down highway 210 from Hodgenville, our road, which is marked as road #2762 is just feet past the 13 mile marker on the right(about 8 miles past Hodgenville McDonalds). A sign for plow day will be there as well. Just 1/4 mile, 3rd home on left. Another sign will be there as well.
  • wvbuzzmaster, KennyP and TAHOE have said thanks
