Hope we get a little rain, my setup don't do so good in hard ground.
I have 6 gals WWF in mine, not sure of pressure....all I get out of the stems is fluid unless I remove tires and set them at an angle. They do wrinkle some though
Posted September 12, 2013 - 11:25 AM
Posted September 12, 2013 - 11:51 AM
With the valve stem at TDC, Should not have fluid. You only to the valve stem that way you can check air pressure without wrecking the air gauge.Hope we get a little rain, my setup don't do so good in hard ground.
I have 6 gals WWF in mine, not sure of pressure....all I get out of the stems is fluidunless I remove tires and set them at an angle. They do wrinkle some though
Posted September 12, 2013 - 01:18 PM
yeah my valve stems are covered up too... might consider letting some out I guess.
Posted September 12, 2013 - 03:03 PM
Been hogging down the plow fields this afternoon. Only liked 20 to 30 minutes finishing, but it started raining! 30+ acres ready, another few acres to mow. The rain, which is good as dry as it is, but the windshield wiper on the tractor is like 100 years old, and I couldn't see a thing. I'll finish the hogging tomorrow, then it's hauling tractors, porta pot, and other things I'll need out there for plow day.
Posted September 12, 2013 - 03:24 PM
CRAPS! I said 3rd home on left./ I keep forgetting the new mobile home, so it's the 4th place on left! Red brick home just before a stop sign. Anyway, you'll see the sign & some of my stuff out back by the tobacco barn anyway.
Posted September 12, 2013 - 03:38 PM
Anyone coming from Lexington way will take 31 from Bardstown toward Hodgenville, but turn left onto highway 470 before getting to Hodgenville. 5 miles on 470 & you come to highway 210. Go left and about 3 miles to my road.
Posted September 12, 2013 - 04:03 PM
Is that after I turned on your road before I go past Fred's place then?
Posted September 12, 2013 - 04:36 PM
Oh yes, long before. When you turned off hwy 210, then took a left at a stop sign to come my way, you just passed Dad's.
Posted September 12, 2013 - 04:50 PM
Mile marker 13 on Hwy 210, that's hwy 2762
Posted September 12, 2013 - 05:09 PM
CORRECTED ADDRESS FOR PLOW DAY IS:
356 Ball Hollow Rd. 42748
This is my Dad's place 2 miles up the road. When you come down highway 210 from Hodgenville, our road, which is marked as road #2762 is just feet past the 13 mile marker on the right(about 8 miles past Hodgenville McDonalds). A sign for plow day will be there as well. Just 1/4 mile, 4th home on left. Another sign will be there as well.
Bumping up.
Posted September 12, 2013 - 05:15 PM
I think Brian can find his way there! LOL
I just sent him a map to my house!
Posted September 12, 2013 - 06:16 PM
Posted September 12, 2013 - 06:25 PM
Do not use a GPS, don't ask how I know :-)
So how do you know Scott?
Posted September 12, 2013 - 07:25 PM
Posted September 12, 2013 - 07:30 PM
By the time I get down there, I should be able to see all the tractors already rolling dirt!
I was going to come down 75 and over through bardstown, google maps tell me coming 71 out of Etown is shorter and quicker.....go figure.
Brian I got as much fluid in these tires as I possibly could when I filled them. With stem at TDC, I get fluid, have to take off to get proper pressure. With these 6 ply sidewall ags, even with no air, probably wouldn't even know.
Edited by TAHOE, September 12, 2013 - 07:33 PM.
