308-8 key switch
9 replies to this topic
#1 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted November 16, 2010 - 06:12 PM
The Wheel Horse 308-8 tractor has a different ignition switch than other models 310's
and 312's or 414's , 416's 8-Speed tractors they another extra terminal on behind the key swith for the ground wire ? Ben
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted November 16, 2010 - 09:51 PM
Try to help here. Not a Wheel Horse Guy but you need to look at the ignition type here.
Does it supply B+ to the system or does it ground the trigger signal?
#3 caseguy OFFLINE
  • 1,629 Thanks
Posted November 16, 2010 - 10:48 PM
If you post the actual model number from the Serial number tag, I might be able to find a manual or at least a wiring digram to help with your question.
#4 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted November 17, 2010 - 04:35 PM
Magnum Kohler 8 engine M8-301511 . I have another question the tractor does not start with the new ignition switch I bought at tractor supply for $13.99 must be defective my 312-8's switch works starts the new tractor but does not shuts off when you kill the power all the wires are not fraided they look good . Ben
#5 caseguy OFFLINE
  • 1,629 Thanks
Posted November 17, 2010 - 05:08 PM
It sounds like Ducky was right. That "extra" tab must be the one that grounds out the trigger signal. In your tractor, it would be the wire that grounds the coil, or as wheel horse calls it, the ignition module and stops the spark. Also, I would need the model number for the tractor, not the engine. I guess I should have been more specific about that.
#6 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted November 17, 2010 - 08:52 PM
21-08K801 model number for tractor my '86 308-8
#7 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted November 18, 2010 - 12:27 PM
The new ignition switch I bought from tractor supply it did not work so I had to rewire it now the tractor starts but does not shut off when you turn the key.
#8 caseguy OFFLINE
  • 1,629 Thanks
Posted November 18, 2010 - 04:19 PM
I uploaded the operators manual to the Wheel Horse manuals section. It has a pretty good section on the electrical system and a breakdown of the key switch wires and their functions. I hope that this helps you out. -Steve
#9 WHEELHORSE418 OFFLINE
WHEELHORSE418
  • 2 Thanks
  • 65 posts
Posted November 18, 2010 - 06:15 PM
Steve I checked out the 308 manual you dowloaded. I have the same electrical breakdown from wheelhorsetractormanuals3 on Yahoo groups copied from thier site but thank you - Ben
#10 papas yards OFFLINE
papas yards
  • 1 Thanks
  • 13 posts
Posted November 18, 2010 - 06:52 PM
308-8 takes a 5 prong switch mine crapped out and had to buy one at the wheel horse show back in june ,, first time there had a good time ,,, PAQPAS YARDS
  • WHEELHORSE418 said thank you
