1966 mf10
131 replies to this topic
#121 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted April 06, 2013 - 09:45 PM
I should try flipping, mounting the wheels on the wide stance, the weights fit the other side better.
But that might mess up the offset for the furrow width. If they preform OK, they look great to me. :D
#122 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted July 21, 2013 - 01:52 PM
Update
Wheel weights > I picked up a set of 8" cast iron wheel weights, 20lbs each, no name on them.
The rims on my MF10 have the tire valve and the greases fitting are on the same side so I put them on the inside, drilled a couple of holes in the rims, mounted the weights on the outside. These weights don't stick out very far and seem to fit good.
For the rear wheels the factory Massey 2 piece weights stick out a fair bit, I have 6x12 AG tires on narrow rims on this tractor, tires are loaded. I also have a set of Farmall cub weights,26lbs each that I put on the outside and they fit good, don't stick out at all.
I'll try it out like this and see and it does, if I need more weight on the rear I can put the Massey wheel weights on the inside of the rims.
Extra weight added
Front weights = 40lbs total
Rear loaded tires = 50lbs total
Outside Rear weights  = 52lbs total (Farmall)
142lbs weight added
Inside Rear weights = 80lbs total (Massey)
222lbs total
  • KennyP and CRFarnsworth have said thanks
#123 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted July 21, 2013 - 02:14 PM
She should stick pretty well now. :thumbs:
They look pretty good on there too.
#124 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted July 21, 2013 - 02:36 PM
:good_job:  :iagree:  :urock:
  • DH1 said thank you
#125 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted July 21, 2013 - 06:53 PM
Looks good Doug. I like the way the fronts look.
So, what are you going to tear up with it?
#126 KennyP ONLINE
  • 53145 Thanks
  • 53295 posts
Posted July 21, 2013 - 07:19 PM
Nice weights, Doug!
#127 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted July 21, 2013 - 07:20 PM
This one I use for pushing and pulling stuff, no PTO driven attachments so more traction is better.
#128 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted August 25, 2013 - 04:56 PM
Picked up a set of Sears weights, they are 35lbs each and have no name on them.
So I took off my 26lbs Farmall weights and put on the Sears 35lbs weights, after I painted them, and now I have 18lbs more weight on the rear.
Best thing I like about these front and rear weights is they don't stick out hardly at all.
I now have
240lbs extra weight added to the wheels of this tractor.
40lbs front
200lbs rear
#129 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted August 25, 2013 - 05:36 PM
Nice looking weights on there Doug. I'll give ya a pass on the repaint, it's a step in the right direction going from straw yellow to Massey red. :D
#130 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted August 26, 2013 - 05:47 AM
You might want beef up those ramps of yours, before you load this
one for a plow day. :D  :poke:
  • DH1 and MH81 have said thanks
#131 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted August 26, 2013 - 05:19 PM
This ones not going to Dan's plow day.
#132 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted August 29, 2013 - 12:12 AM
Cool tractor! Keep up the good work!
