1966 mf10
131 replies to this topic
#46 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted April 25, 2010 - 09:57 PM
Started reassembly tonight, got the trany mounted adjusted and tightened up the steering column, installed the rear lift kit next is the tower and vari drive parts.
#47 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted April 28, 2010 - 10:18 PM
More assembly, Varidrive all in and adjusted, motor, S/G installed and it runs.
#48 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted June 22, 2010 - 08:24 PM
Got back on the 66 tonight, been a while since I've done anything with this, pulled the trany out again to fix the oil leak, split the case, used some RTV, put it back together and left it sitting on 1 end. Fixed the gas leak in the carb, drain valve in the fuel bowel, put a rivet in it with a bit of epoxy. Organized my parts for it so I know where I stand looks like I got everything but a good steering wheel, I knew the moment I broke it trying to take it off it was going to be a problem. Anyway got to push myself to finish this thing.
#49 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted June 24, 2010 - 10:14 PM
Put the trany back in tonight, filled it with oil and no leaks. Put the fuel bowl back on the carb., hooked up the gas line and no leaks there either. Fired it up checked the Vari-Drive adjustment and seems to be OK, working on the brakes now, have the early style and the later style units trying to see which one works better, I'll have to finish that up tomorrow, that's as far as I got tonight on it.
#50 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted June 25, 2010 - 02:20 PM
Sounds like its coming together good.
#51 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted June 25, 2010 - 10:03 PM
Well I got the brake all sorted out, found a another difference between the 66 and later models, brake unit on the 66 is bolted to the trany where later models it's bolted to an extra bracket that is welded to the frame, both brake units are different but work the same way. Found a new brake band in my parts bin, mounted on a the newer style unit, I removed the band and mounted it to the 66 style unit and now I got brakes.
#52 jdslednut OFFLINE
jdslednut
  • 681 Thanks
  • 851 posts
Posted June 25, 2010 - 10:58 PM
That's my number one rule in the shop at school - know how you're going to stop it before you start it! Maybe #2, you know - Safety First! It's good to hear it's coming along nicely.
#53 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted June 27, 2010 - 05:21 PM
Working on it again today, got the foot boards on, all the gray sheet metal on, mounted the grill, front axle drilled out 3 spots for grease fittings, mounted it, put the wheels on, it's been a long time since it sat on it's tires. Working on the wiring and dash and the red sheet metal, hood, toolbox and seat. Was hoping to paint red today but it's not good weather for that. That's as far as I got so far.
#54 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted June 28, 2010 - 06:07 PM
It finally stopped raining and cleared up, here's some pic.
Going to spend some more time on it tonight, work on the wiring and prepare the red pieces for paint and yes I plan on 2 toning the wheels.
#55 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 181 Thanks
  • 1009 posts
Posted June 28, 2010 - 08:51 PM
very nice
i bet youll be driving it before its back together it looks so nice :P
#56 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted August 02, 2010 - 07:54 PM
Had the day off work today, spent some time on the 66 and got some red paint on it. Still have a few small things to finish off, control cables, batt hold down,but it's finally coming together. Hope to finish in a few days.
#57 jdslednut OFFLINE
jdslednut
  • 681 Thanks
  • 851 posts
Posted August 02, 2010 - 09:57 PM
I want to see some pictures of that beauty when you're finished. :thumbs:
#58 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted August 05, 2010 - 09:33 PM
Ordered Decals today, had a hard time getting a hold of them but once I did everything got sorted out, them seem like good guys.
#59 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted August 10, 2010 - 09:28 PM
Drove it tonight for the first time, seems to be good, starts easy, runs smooth and steady, all the gears, clutch, Vari Drive parts work, still a couple of small things to sort out but at least now it's usable.
Pictures tomorrow.
Edited by DH1, August 10, 2010 - 09:34 PM.
added content
#60 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted August 11, 2010 - 05:55 PM
Pictures
As you can see still needs decals, lights to be installed, missing 1 front wheel cap I know I painted 2 of them. Front tires are wheel barrow tires, need to find something more suitable, narrow rear turf tires need to be painted, PTO pedal to go on and it's done.
Still don't have a good original steering wheel so I used what I had.
Every thing works even the voltage regulator that came with the tractor.
