Snow Blade Question
11 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 24, 2013 - 01:06 PM
Does the mule drive have to be removed to install the snow blade mount on a JD314 ?
larryd
  • JRJ said thank you
#2 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 24, 2013 - 03:17 PM
Pretty sure it does Larry. I know my Blower uses the same mounting points as the Mule Drive for the mower on the 318.
  • larryd and JRJ have said thanks
#3 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted July 24, 2013 - 04:23 PM
Blower = yes (possibly no but would not bet on it)
Blade = no
The drive assembly for the blower occupies the same space as the mule drive under the tractor.  The blade does not require that space.
#4 hdg4400 OFFLINE
hdg4400
  • 296 Thanks
  • 359 posts
Posted July 24, 2013 - 04:42 PM
Is this the 54 blade? If so, the Operator's manual doesn't say anything about the mule drive and Trav1s is right, as usual.
Harlan
#5 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted July 24, 2013 - 05:35 PM
I think you would have to remove the deck.  The drive should be able to stay.
#6 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted July 24, 2013 - 06:00 PM
On the 120/140/300 series the deck mounts are independent from the front blade mount.  The only reason I could see a need to remove the mule on the 120/140/300 is to clear the tensioner on the blower.  I will check and get back.  Might have to mount the blower on the 314 just to check it out.  :D
  On the flat fender 110/112 & 200 series the lower points of the front mount are used to attach the draft plate for the deck.  I am pretty sure the deck needs removed on the 200 to mount the blade or blower.
Edited by Trav1s, July 24, 2013 - 06:01 PM.
#7 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted July 25, 2013 - 09:38 AM
Just snapped these pics for reference. The first two are of the front of the 314 with the mule drive and deck in place. The next two are of the blower. The drive unit on the blower will hit the mule drive but everything will attach without interference. I know a blade will mount and work while the mule and deck are installed as I looked at a 314 for sale that had both mounted at the same time.
Edited by Trav1s, July 25, 2013 - 09:44 AM.
#8 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 25, 2013 - 10:41 AM
photo 1.JPG photo 2.JPG Thanks guys . I tried to install yesterday but I can't seem to get the top spring loaded pins to engage the holes
larryd
#9 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted July 25, 2013 - 11:21 AM
Will they move without the blade mounted?  Pull out on the pin then twist.  Same pin used to attach the deck.
#10 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 25, 2013 - 11:45 AM
Yes they work just fine
larryd
#11 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted July 26, 2013 - 07:10 PM
if you remove the deck the mule will have to come off the belt is what holds the mule in place .
Edited by Gary400, July 26, 2013 - 07:51 PM.
  • JDBrian, larryd and JRJ have said thanks
#12 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 27, 2013 - 12:05 AM
I didn't want to remove deck or mule drive. Blade is totally hyd
I have seen some GT's with them in place.
Mainly I just wanted to mount it to see how everything works for now.
larryd
