Step Drill Bit Question- Metal Thickness
14 replies to this topic
#1 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted July 23, 2013 - 12:51 PM
I need to drill a hole that is 1 1/8" in the new frame for my PK dump tractor (HERE) to put the front axle pivot pin through. The problem is that a drill bit that large will cost me at least $35! I found some step drill bits on eBay for less then half that, I would rather purchase a step drill bit since it is cheaper, and I would be able to use it more then a huge 1 1/8" bit after this one hole.
The thing I am unsure of about the step bit is, can I drill something thicker then how tall each step is? For example, if the step is 1/8" can I drill through something that is 1/4" thick? Obviously I can't if I want the hole to be the size of one of the middle steps, but if I want the hole to be the size of the largest step, can I just go right through? It would make sense to me that it would work, but I want to make sure before I buy it and it does not work.
  • JRJ said thank you
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 23, 2013 - 12:57 PM
I've never used a step bit. I use holesaws to drill large holes in metal and they will do the job if you get a good bi metallic one. The problem with holesaws is that the hole is always a bit larger than the nominal size. So if you are looking for a precision fit it may not be a good choice. A 1" will likely be slightly smaller than 1 1/8 and a 1 1/8 will be a bit larger.
#3 chaentjens OFFLINE
chaentjens
  • 101 Thanks
  • 122 posts
Posted July 23, 2013 - 01:25 PM
Yes it will work. Use plenty of cutting oil on sliw speed. You will have to go in from both sides to fully drill a hole that thick!
Sent from my SPH-L900 using Tapatalk 4 Beta
#4 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted July 23, 2013 - 01:26 PM
Ryan I had used a step drill once and really liked it, I bought the one that goes up 1/2" and it was about $13.00 at Lowes.
Dick
#5 IamSherwood OFFLINE
  • 8,391 Thanks
Posted July 23, 2013 - 01:38 PM
Yes Ryan, I agree, it'll work.
Step drills are great to have around. Especially for sheet metal.
#6 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,485 Thanks
  • 5,777 posts
Posted July 23, 2013 - 02:08 PM
I have a few sets of them and they are great for drilling any large hole in almost any metal!  The nice thing about them is that you don't have to stop and install the next size drill in your chuck to continue the job!..  There are step drills available with different size or deep 'steps' but they are a bit more $$$..  It's still a heckuva lot cheaper than buying an assortment of all of the drills that they will replace.   Bore away! :rocker2:
  • HDWildBill said thank you
#7 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted July 23, 2013 - 04:00 PM
Yes Ryan, it sure will work.  I've used them plenty of times for punching out bigger holes in heavier steel plate. The other advantage of having a step bit is for when one has to make a hole in something thin . A regular twist bit has a tendancy to grab and twist right at the bottom of the hole ( I have one  broken drill shaft from just that.... using big regular  bit  :mad2: )   IMHO The step bit is sure better for the thin metals as it grabs less.
Edited by marlboro180, July 23, 2013 - 04:01 PM.
#8 MH81 OFFLINE
Posted July 23, 2013 - 04:26 PM
Slow and good oil. The step bt seems to get hot faster, but I find myself reaching for them all the time. Very convenient
  • IamSherwood said thank you
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 23, 2013 - 04:36 PM
It must take quite a while to punch a large hole in 1/4" plate with one of those. You are drilling away all the metal. With a hole saw you are just cutting a narrow bit around the circumference of the hole and a 1/4" hole in the centre.
#10 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted July 23, 2013 - 05:14 PM
Will it work >>> maybe I say.
As always it really depends on the tool, I wear out good 50 buck 3/4" step drills every few months working in sheet metal.
#11 TomLGT195 OFFLINE
TomLGT195
  • 3,834 Thanks
  • 2,816 posts
Posted July 23, 2013 - 06:56 PM
:ditto:  I have used for 1/4" before   just go slow and  clamp piece, flip and do again. you will find a lot of uses for the step drill once you have it.
#12 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 23, 2013 - 06:58 PM
I have never used step drills, but would like to give them a try. But I have to agree with Brian an arbor and a set of good hole saws would be a lot cheaper. I like the ones I have.
#13 Gary400 OFFLINE
Gary400
    JD,junkie
  • 225 Thanks
  • 768 posts
Posted July 23, 2013 - 08:03 PM
they work good in sheet metal not so good in iron .
#14 ghack OFFLINE
ghack
  • 29 Thanks
  • 35 posts
Posted July 23, 2013 - 08:23 PM
they can be sharpened also as with most good tools.
#15 Alc ONLINE
  • 6,910 Thanks
  • 7,472 posts
Posted July 23, 2013 - 09:14 PM
Not to get too far off topic but the fellow who lowered the front axle on my 2418 just cut the hole with a torch and welded it in place
