Fell Off The Wagon--- Again
bolens 1886 husky 1886
33 replies to this topic
#31 Utah Smitty OFFLINE
Utah Smitty
  • 2307 Thanks
  • 2003 posts
Posted July 24, 2013 - 07:36 PM
Any suggestions how to get the pipe plug out of the tranny case so I can check the fluid level.  The protruding tab is broken off flush.  I don't want to drill and easy out for fear of putting chips in tranny.  I've thought of drilling a shallow hole on the circumference and use a punch and try to drift it out...
Any suggestions appreciated.
#32 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted July 24, 2013 - 07:57 PM
Maybe a dremel with a small cutoff wheel to slice a slot in the plug.  Then, with a hand impact wrench & a slot bit, it oughta pop it loose.
#33 Utah Smitty OFFLINE
Utah Smitty
  • 2307 Thanks
  • 2003 posts
Posted July 25, 2013 - 12:15 AM
Good suggestion, Dan...
I took a small punch and hammer to see if I could drift it out.  Turns out the plug is plastic--spun right out.... now I'll just glue or screw a knob on it so I can get to it.
I know how to do most of the mechanical things it needs, but the seat pan had a small diesel engine fall on it, and has a large gash and is badly bent on the left side--guess I need to find a good body and fender man...
Smitty
#34 Utah Smitty OFFLINE
Utah Smitty
  • 2307 Thanks
  • 2003 posts
Posted July 26, 2013 - 11:36 PM
Well, I finally got it going... had to get it off my trailer so I could.... ahem..... go pick up another tractor--a Sears ST or SS10 with plow, discs, snow blade, mower, and a bad input shaft on the tranny with a Tec 10 repower...PLUS a brand new Sears Snowblower with mule drive for a GT 18---thinking of giving it to mom for Christmas.
I had some problems getting the Kohler 482 to run... wasn't getting fuel to the carb.... pulled the carb off to clean it  and ran into a major snag... which I'll discuss in a new thread as I need some major input on it...
anyway, put a carb from a K321 on it-couldn't hook up the linkage of course, and gravity fed the gas from a snowblower tank bolted to the dash support and she moved out smartly... hydraulics work, hydro works--gotta get used to the foot shuttle, and the engine runs well.
Here's some pics---
OFFLOADING THE BOLENS 1886 2.jpg OFFLOADING THE BOLENS 1886 3.jpg OFFLOADING THE BOLENS 1886 4.jpg
Edited by Utah Smitty, July 26, 2013 - 11:37 PM.
  • olcowhand and MH81 have said thanks
Also tagged with one or more of these keywords: bolens 1886, husky 1886
