* * * * * 1 votes
Case 444
124 replies to this topic
#46 cjg2283 OFFLINE
cjg2283
  • 35 Thanks
  • 60 posts
Posted July 25, 2013 - 10:20 PM
Can you tell what that is attached to the left foot rest? I thought maybe flow diverter but see no control handle.Looks almost like hydraulic motor different color for Case part.    Let me know if you cant find bracket .
Are you talking about that thing with a little black knob? I can take a better pic tomorrow. . .
#47 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 25, 2013 - 10:27 PM
I'll bet some one cobbled in the lines from the rear PTO, The other foot rest has a board or something attached, the wiring is a mess, the Previous Owner took the fan and front PTO clutch off, hopefully he didn't run it long with out a fan. Previous owners are all mechanical engineers and fabricaters dontcha know
#48 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted July 25, 2013 - 10:32 PM
That has has a knob it's more than likely flow control to keep the tiller from pushing tractor.Just odd color,
  • OkieGt said thank you
#49 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted July 25, 2013 - 11:03 PM
I see you need some motor mounts. Go to McMaster-Carr part # 6008k33   $10.67 each.
#50 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 25, 2013 - 11:14 PM
I was kinda guessing , no way I can see it
#51 gopher OFFLINE
gopher
  • 750 Thanks
  • 753 posts
Posted July 25, 2013 - 11:24 PM
I think we have a few of those around here too. Makes things a little more interesting.
#52 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 25, 2013 - 11:27 PM
I dont care how much money it takes, I really, really try to use original parts and put things back as it was original, nothing worse than hanging wires, missing brackets, side panels, deck chutes, that were all thrown away becasue the PO was too lazy to reinstall them
#53 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted July 26, 2013 - 12:12 AM
Looking at the engine,it seems to be missing the top shroud--that goes over the cylinder head.
Smitty
#54 cjg2283 OFFLINE
cjg2283
  • 35 Thanks
  • 60 posts
Posted July 26, 2013 - 05:43 PM
Gave her a little bath, nothing major just cleaning to look for leaks in the hydraulics.
#55 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 26, 2013 - 05:57 PM
looks like you have the often sought  splitter valve
  • dropped82 said thank you
#56 dropped82 ONLINE
dropped82
    Nut Case
  • 2,451 Thanks
  • 1,797 posts
Posted July 26, 2013 - 06:21 PM
Wow. Nice cleaning job. You wanna do mine next. I have beer!
Eric
Sent from my XT897 using Tapatalk 2
  • cjg2283 said thank you
#57 KennyP ONLINE
  • 37,510 Thanks
  • 45,512 posts
Posted July 26, 2013 - 06:26 PM
Bet she feels much better! Looks like you even got behind the ears!
  • dropped82 and cjg2283 have said thanks
#58 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 26, 2013 - 07:22 PM
tell us what you used, how you did it. I think cleaning may be the toughtest job of all
#59 cjg2283 OFFLINE
cjg2283
  • 35 Thanks
  • 60 posts
Posted July 27, 2013 - 03:07 PM
Pressure washer. Need to do a little more up front. Just got back with all the wire for rewiring everything. I need to find the correct size batter to fit in the tractor as well the one that's in it is too big. It works but doesn't fit well....
  • KennyP and OkieGt have said thanks
#60 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 27, 2013 - 03:21 PM
A small lawn tractor battery will work, just get the one that has 325 CCAs or more. Your Case has a manual PTO and only uses lights and starter for electrical needs, it wont need as much as a tractor with an electric clutch drawing 35 amps will running. In fact tractors using electric clutches are not sending much if any of a charge back to the battery while mowing, only when the electric clutch is off
