Allis 716H winter project underway
83 replies to this topic
#61 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 25, 2011 - 08:57 AM
Just got caught up on your thread. The tractor looks awesome!!!
#62 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted February 26, 2011 - 09:01 AM
Thanks to everyone who has replied.It's slowly comming along and will be ready to use once spring arrive's. On another Note I got a e-mail from the PO and he's found the original grill and the rest of the motor parts.[not that I'll be rebuilding it] but its good to have just in case I ever have to do so. I'll be picking that stuff up today as he's meeting me half way less driving for me.Larry
#63 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted February 26, 2011 - 10:14 AM
Sounds good you never know when your going to need those extra parts.
#64 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted February 27, 2011 - 06:15 PM
Seeing that I'am waiting for the Decals to come in and the tractor is done for now I brought the tiller in to start going through it.I can't beleive how heavy the tiller is. It's a monster for sure and very heavy to move around.Here's some pics of it, brought it inside on a pallet after blowing some snow today.Larry
#65 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted March 03, 2011 - 09:32 PM
Slowly did some stuff this week with the tiller took it apart and cleaned it all up.Washed it off with a degreaser then washed with water.I let it dry overnight and sanded some of it down.Actually did all the black pieces first.Today I sanded the rest of it down.Seeing that the ID# is just a decal I'll have to make up a small plate with the number stamped into it.Then I'll pop rivet it onto the frame of the tiller once it's all painted.I think once I make up the plate for the tiller I'll make up one for the mower deck as well as the snowblower as I haven't put the ID#'s back on them yet.The tiller is ready for painting now,just not sure when I'll do it.
I made the ID plates today and located the place on the tiller where it's going to me mounted.Once I had the holes drilled I stamped the ID#'s into each corresponding plate,and then sprayed them with a black gloss paint. .Larry
Edited by massey driver, March 04, 2011 - 02:03 PM.
Added in pics
#66 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted March 05, 2011 - 06:03 PM
I made a muffler for the Allis but it was still to loud,so I added a second one to the other one.I decided to do it this way rather then use a larger pipe so as to keep the clearance between the grill and muffler to 1".First thing I did was cut the first muffler shorter by 3".I cut it shorter because it was interfering with the oil dip stick tube and I couldn't get it into a good position.You can see the inside of the first one.I cut the outlet pipe off the first muffler and added the second one onto that pipe.I then had to make a new outlet pipe with holes drilled into it,for one of the internal baffles.The other end the outlet part had to be kinda bent down sort of like a S to beable to allow the pipe to exit through the side of the hood. I'll do more tommoro.Larry
#67 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted March 05, 2011 - 06:30 PM
Today I did more on the muffler.First thing was to add a second baffle to the added muffler.I used a piece of flat bar and drilled holes into it except for where the inlet pipe is comming from muffler #1.I welded it into place and then put the outlet pipe into the muffler I also welded it in place before adding the end caps.The muffler sit's in a good spot now and it doesn't interfere with anything[plus there's 1" clearance between the muffler and grill]. The hood even closes around the outlet pipe perfectly.I had to start it up to hear how quite it was.I was very happy to hear the big difference.Now I'am happy with it.Larry
#68 olcowhand ONLINE
  • 40,351 Thanks
  • 31,170 posts
Posted March 05, 2011 - 07:31 PM
Looking nice Larry!
#69 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted March 09, 2011 - 01:20 PM
Painted the tiller the other day and put it together this morning.I'am getting closer to having this winter project done.:laughingteeth:Larry
#70 nra1ifer OFFLINE
nra1ifer
  • 674 Thanks
  • 1,531 posts
Posted March 09, 2011 - 01:45 PM
Looks good!
#71 Chuck_050382 OFFLINE
Chuck_050382
  • 275 Thanks
  • 1,498 posts
Posted March 09, 2011 - 02:12 PM
Larry, I have my 990 all tore apart and stacked on a pallet, can I ship it up there for you to finish? It was my winter project last year and all I have done since last march is move it around and prime a few parts.
You are doing a great job. Keep up the good work.
#72 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted March 09, 2011 - 03:20 PM
Larry, That muffler looks great, and so dos the rest of the tractor. I like the idea of making I.D. plates for all of the attachments, what did you use, steel or Aluminum? How did you figure the amount of holes in your baffles, so back pressure would be right?
Great Job !!
#73 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted March 09, 2011 - 05:05 PM
Great Job !!
For the ID plates I just used some 1 1/4" steel flat bar that I had laying around. The holes in the baffles and pipes I just drilled enough 3/16" holes so that I felt comfortable that there'd be enough to allow the exhaust to flow freely.LOL Larry
Hey Chuck I have stuff sitting on Pallets as well that gets moved from one spot to the other to make room.LOL Yeah winter projects seem to pile up .I still have some stuff that I've got on hold as well.Larry
#74 JoshBrown OFFLINE
JoshBrown
  • 20 Thanks
  • 277 posts
Posted March 09, 2011 - 09:16 PM
The tiller and the muffler look great!!!
#75 massey driver ONLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted March 11, 2011 - 08:15 PM
Finished off the Allis today.:laughingteeth:Put the decals on yesterday and today.I also changed one drive plate that the holes were egg shaped,now the vibration is gone.I also set the govenor speed down as well.It was running way to high rpm.Poured some sea foam into the tank today as well and let it run a bit.It's put away now untill spring.I took some pics of it today as well as the attachments.I left the stuff on the pallets as it's easier to move them back into the storage shed.It was a cloudy overcast day today so the pics don't really do justice of the tractor and attachments.But it's done and ready to use now.Larry
